Question about Olympus FL-50 TTL Flash
Need more power for fl-50
After not too many flashes the AA batteries slow the flash down considerably. What combo from Olympus do I need for an unending number of flashes (300 or so) before the battery drains?
Use Sanyo Eneloop NiMH batteries. These are slow-discharge batteries that will keep you going for a long time. Cheers
Posted on Jul 29, 2008
Flashing auto check and test/charge
This means that your batteries are low on power.
Oct 07, 2007 | Olympus FL-50 TTL Flash
CR-V3 not working
I have read in Forums that FL-50 will not work with RECHARGABLE CR-V3s
Oct 08, 2006 | Olympus FL-50 TTL Flash
Settings that must be set before... the external flash feature
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built-in flash and the Olympus FL-20/FL-40/FL-50 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Connect these external flashes...
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable - this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Any settings that must be set before you can use the external flash feature
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Connect to external flashes
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-5060 Wide Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
External Flash
Yes, the FL-20 Flash and the FL-36 Flash are both available accessory flashes that cover a wide variety of lighting needs. The FL-50 is designed for advanced to professional photograhphers who need the greatest light output.
Aug 29, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Olympus FL-50 TTL Flash Logo
210 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
