Question about Nextar MA833A5S MP3 Player
Nextar mp3 will not stop freezing up
I have a nextar mp3 512MB.
It use to work perfectly fine and then one day it started acting silly. Sometimes when I turn it on, it doesnt want to and an hour glass will show up, then maybe turn off. Sometimes it will got to the changing modes area but then it will freeze. If I DO get to get to my songs, it lasts about a mintue before it freezes, goes back to the hourglass, or completely shuts off. I wont do anything when I plug it into the computer anymore, and now sometimes it wont even turn on. I dont know what to do. :(
SOURCE: nextar-NO FILE
I had the same problem and the Nextar support line couldn't fix it. They said send it back. To much hassle so I kept pushing buttons and finally figured it out. The player was not in the play music mode, but the record mode somehow. Screen read DVR, not MP3. Try pushing and holding the mode button in, not in the direction of the arrows, but straight into the housing. Hold if for a while and then you will enter the world of settings, voice recordings, music playing and much more. Good luck and I hope this helps!
Posted on Jan 11, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: i cant install nextar mp3 to the computor
Make sure you have a compatible version of Windows:
the compatible versions (and the user manual) can be found at:
http://www.nextar.com/frontend/mp3_players.asp?MODEL=MA566&subpr=&categ=
Posted on May 23, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: can't load songs on nextar mp3 1 GB ma933a- 1p
There are several possibilities:
1) The songs you are trying to load to the Mp3 player are not compatible with the Nextar - a good test for this would be to connect your Nextar to the PC, open Windows Media Player, and click the Library tab, then the Sync tab - if a little blue "i" appears next to the song, it will not work with your Nextar. In fact, any song that is not in mp3 format or unprotected WMA (very few WMA's are unprotected unless you Ripped them directly from CD) will not play in the Nextar.
2) You have the Hold switch engaged - unlock it
3) The PC's you are trying to connect it to are running Windows Vista - not compatible with Nextar
-Tha Mp3 Doctor
Posted on Feb 05, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Formated nextar ma933 mp3 player
That player is officially toast. There is no recovery software or firmware upgrades for that device - once the key system file is delted, it cannot be recovered.
SOURCE: The ma933a nextar model skips over songs every 10 secs!
you have the play mode set to "intro",
how to solve this;
1) start playing a song.
2)Press the "Mode" button quickly, don't hold it down, just press it quick.
3)Select Play Mode by pressing the Mode button
4)Select "N" normal
all done.
Posted on Nov 16, 2009
1999 Dodge 1 ton won't start sometimes. There's no set pattern to it. Sometimes it'll crank right up, but other times ill have to try it everyday for a week before it'll start.
when it doesnt start does it crank? if it cranks all day and doesnt start spray some starting fluid in the throttle body and see if it starts and then if it dies then you are not getting enough fuel pressure but if it doesnt start then your iginiton system is acting up or your crankshaft sensor could be bad
Sep 13, 2013 | Dodge Ram Cars & Trucks
1995 sl1
replace ignition coil
Jun 20, 2013 | Saturn Cars & Trucks
When you turn the key it has trouble starting sometimes you turn it it doesnt do anything, sometimes it turns the lights and radio on and other times it starts to crank and doesnt so far it has always...
I would check the ignition switch, these are prone to key and barrel wear, Sounds silly but if you have another key try that as a newer,less worn profile key can sometimes help with a solution
Oct 05, 2010 | 2005 Ford Focus
My phone wont turn on properly. I try to turn it on and it freezes. It gets as far as the screen that says Nokia then the screen with 5 little dots that flash back and forth then it freezes on the second...
For resolving your Nokia N900 problem, I recommend a firmware replacement to reinstall the system software. Once these devices start acting silly, this is generally the way to fix them.
Full instructions and software are available here.
I hope that helps.
Feb 15, 2010 | Nokia N900 Smartphone
I have a 2003 Pontiac Grand Am. Earlier this year it began having starting problems and I learned that the fuel pump was not turning on sometimes when i put the ignition switch to on. (wouldnt hear it) ...
It is most likely the Ignition switch. I have replaced several for this exact simptoms.
To check it, you test the power for the fuel pump relay.
When the ign switch starts acting up it will not power up the fuel pump relay portion of the fues box.
You can check it with a test light.
On a day when it starts and runs fine, pull the fuel pump relay, turn key on and probe the socket with test light and make note which ones have power to them.
Then one day, when it dont start, dont turn the key off yet, pull the relay, and retest, and compare.
If there is no power where there used to be power, replace the ignition switch.
Hope this helps
If it does please leave some testimony
Nov 09, 2009 | 2003 Pontiac Grand Am
Computer not recognizing video card maybe?
If you have a onboard graphics on your mobo they may have been turned on somehow I would check there and disable them if they have been.
Aug 15, 2009 | ASUS Extreme AX800XL Radeon X800XL, (256...
I've got a 1991 BMW 525i which has done 253,000 km. It's been a good car but, the instrument panel on the dashboard has gone silly over the past couple of weeks. When I first start the car in the morning,...
this is just a rough guess, but i think it would be the battery or the alternator. Some part store have testers that they will check both for free.
Aug 14, 2009 | BMW 525 Cars & Trucks
Got in my jeep turned the key and nothing! it will not start.
remove the small wire going to starter motor solonoid and put a test light on it --if it doesnt light up when key is turned then work your way back till you find the fault,relay? contact switch on ignition??
Apr 11, 2009 | 1995 Jeep Grand Cherokee
Nextar MA833A5S MP3 Player Logo
Top Nextar Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
topcat7736
Level 1 Expert
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
