Question about ASUS P4S533-VM (P4S533-VM/L) Motherboard
SYSTEM WONT POWER ON
I just obtained an ASUS P4S533-VM to replace the same board in my system that blew after my liquid cooling system sprung a leak.
I have replaced the mobo and all the cards as well as a new power supply; that I know to be good, all myconnections are tight and proper yet the system will NOT power up.
The onboard LED and NIC lights are active the system just will not power up.
Any suggestions
  • 55 Answers
Try to replace a CPU
Posted on May 22, 2008
Is there a current motherboard that will fit in a Sony Vaio pcv-RZ22g case to replace an old Asus P4S533 motherboard?
Desktop computer cases have mountings that suit the majority of motherboards.
You most like need a new switch mode power supply as the existion one won't have the correct power connectors and won't supply enough power.
Jan 22, 2013 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Tengo una placa base asus m2v y no encuentro el driver de la tarjeta de audio , que viene integrada en esa placa. gracias
Hi, you can download the sound driver here at ASUS:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=15&m=P4S533-VM&os=&hashedid=n%2fa
Remember to select your operating system.
And select the audio driver.
The driver you have downloaded needs to be unziped before
installation.
Hope this will help you.
Apr 14, 2011 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Dont have audio & video drivers for Asus P4S533-VM Motherboard
1.Go to this site:http://support.asus.com/download/download.aspx?SLanguage=en-us
2.Choose Motherboards
3.Choose Socket 478
4.Choose P4S533-VM
5.Choose OS and you are all set
Nov 20, 2010 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
I need VGA / video driver for ASUS P4S533-VM
1. Click on this link: http://support.asus.com/download/download.aspx
2. Click on Select Product. Click on motherboard.
3. Click on Select Series. Click on socket478
4. Click on Select Models. Click on P4533-VM
5. Select your operating system.
6. Download the drivers you need.
Thank You for allowing me to help.
Nov 11, 2010 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Where i download my audio dirve for ASUS P4B533-VM drive
You can download the drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
Sep 18, 2010 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
I can't recognize what specific RAM this motherboard accepts..
Dear sir,
In reply to your post- Generally now a days we use DDR400 RAM(DDR 1) for this type of motherboard.So DDR 400 RAM is More compatible then other RAM,you can use this RAM for your motherboard to obtain good performance.
good luck
chandrashekhar
Aug 04, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
ASUS P4S533 BIOS is not recognizing my new SATA HDD, what do I need to do to fix the problem? The BIOS is vesion 1007. Thank you.
That's because it didn't come with a sata connection. I downloaded the manual & this board isn't sata compatible.
Jul 18, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
ASUS P4S533 Motherboard 1.77GHz CPU does not boot with 1GB DDR400 RAM
Make sure you are using the supported memory type. Check the user guide. Also check if you have installed the latest BIOS firmware from ASUS.
Oct 30, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
PC powering off
you probably have a setting in the BIOS for the PC to shut off when the processor reaches 70C, you can disable that, but it can get hotter and hotter till the CPU melts. So try putting some more liquid in the PC.
Jun 09, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
CPu fan turns for 1 second and then stops.
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
Apr 07, 2007 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
ASUS P4S533-VM (P4S533-VM/L) Motherboard Logo
161 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
