Question about Canon Office Equipment & Supplies
I have VISTA, A DR2580C and Capture Perfect 3. When I select Capture 3 a message comes up "Scanner is not found check cable" I previously installed Capture Perfect 3 then upgraded it using the Cannon DR2580C upgrade download for VISTA. I must be doing something stupid. This system worked on my previous computer with Windows XP I have Adobe Acrobat 8.0 loaded and it ioerates as well
    Sergeant:
    Champion:
  • 271 Answers
Hey...dont get me wrong...we all make mistakes...am sorry again for that mistake...
if you are intrested try this way again...
> goto device manager > right click that is yellow > select uninstall driver > and repeat it to the other named something scanner
and > do again the installation again (what i told you in chat) for all yellow flags > restart windows >
ask me any prob at my profile? Roshan89...
Posted on May 28, 2008
I hava a canon dr-2010c scanner. but when I scan the paper through capture touch 2.0 than scanning very fine but when I scan through capture perfect 3.0 than show black page scanning.
Normally it is advisable to use only one Scanning Software. The software has various files which may overwrite the previously installed version. The later version works good.
It is also possible that the brightness/contrast settings in Captureperfect 3 is not proper. Try scanning after altering these.
S. Mohan, India
Apr 03, 2014 | Canon DR-2010C Flatbed Scanner
The cannon DR 2580-C resinstalled to new computer
Capture perfect is scannig software, it is not a driver. You can download driver from this site. http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11360
Install driver and use Captureperfect to scan.
S. Mohan, Chennai, India
Feb 21, 2009 | Canon DR-2580C Path-Through Scanner
Missing the disc
Well the good news is you don't have to pick up a disc :-) . You can actually download the driver for the scanner here (the driver is the software that allows the computer to see the scanner)
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=7181
On that page you want the second one down (2080INF.exe)
Here is what you are going to need to do:
  1. Download that file
  2. Double Click on the file and then hit "Run" followed by "Unzip"
  3. Click the "Start" button
  4. Click "Control Panel"
  5. Double Click "Scanners & Camera's"
  6. On the left menu (it is the blue menu on the left) select "Add Imaging Device"
  7. A wizard will now come up , click "next"
  8. It will now ask what kind of scanner/camera you want to install, on the bottom right is a button that reads "Have Disk" ; click that
  9. Hit "Browse"
  10. Navigate to the folder where you un-zipped the original download to. By default it went to "C:/DR208C/INF" - In that folder you will see a file named "CANODR2K" , double click it.
  11. Hit "Ok"
  12. Select how it is connected (USB or SCSI)
  13. Finish the wizard
And thats it! Now your scanner is installed on the computer and you can scan......
Also on the original CD is a software called "Capture Perfect" , which is the software that is used for actually scanning with your scanner , you can download that here: http://www.softpedia.com/get/Multimedia/Graphic/Graphic-Capture/Capture-Perfect.shtml
Oct 02, 2008 | Canon DR 2080C Path-Through Scanner
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
Incompatible with Vista 64-bit
Eine Lösung die geht ist ein 2. kleinPC mit winXP32 den über Remotedesktop anbinden. Das ist komfortabel und funktioniert garantiert immer.
Aug 26, 2008 | Canon DR 2080C Path-Through Scanner
New Computer; Windows VISTA; Scanner Canon DR2580C drive loaded from Internet. Capture Perfect 3.046 loaded from INternet. Att4empting to scan a document produces a info box with the words "Scanner is...
go to device manager and make sure that the device is working properly because if the driver for the scanner may be missing and you will have to acquire it to use your scanner. if you need anything else please feel free to leave a comment.
please rate me. thank you.
May 28, 2008 | Computers & Internet
Canon Unknown Error
Please run Scandisk on your computer. If the problem persists even after this, reinstall OS. You need to reinstall other applications also.
S. Mohan
Feb 07, 2008 | Canon DR-2580C Path-Through Scanner
Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Jan 31, 2008 | Canon DR-9080C Path-Through Scanner
98 people viewed this question
old marine
old marine
