Yesterday, I bought a Sanyo 26" flat screen TV Model DP26648. The color is poor and I have tried to cursor up and down in the color, tint, contrast, brightness, etc. I don't seem to be able to seem to be able to strike a happy medium. Is there some secret as to do this. C. Baltzagler e-mail: tpd743@windstream.net
SET CONTRAST AT ABOUT 75 PER CENT COLOUR 50 PER CENT BRIGHTNESS 40 PERCENT LEAVE TINT ALONE.
THIS IS A ROUGH GUIDE BUT I HOPE IT HELPS.FOR BETTER RESULTS USE A DVD LIKE RATATOUILLE AND USE THE SET UP MENU.
CABLE GUY.
Posted on May 21, 2008
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
I last the tv remote model dp26648 i want remote
Setup codes to check with Sanyo brands are 004/ 013. If you wish to get more details about four digit and five digit codes, check this link. There is setup code list to many brands of remote controls. Just see and check which brand has setup code to Sanyo. It will make you remote selection easy. There is an other link. Check this too.
Feb 20, 2013 | Sanyo DP26648-R 26 in. LCD TV
2008 Sanyo DP26648 has a black screen but has sound
Check its T'Con board. This is a common fault to all type of LCD TVs
Apr 02, 2012 | Sanyo DP26648-R 26 in. LCD TV
Neither "solution" is a solution. Anyone actually
Your problem is the T-con board. This is gone bad/faulty. I would advice you to replace it with new T-con board and your unit will back to normal again. You may look for the replacement online. Try ebay.com or shopjimmy.com.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 16, 2011 | Sanyo DP26648-R 26 in. LCD TV
I need to hook up to digital cable
Connect the cable to your TV's antenna input jack. Through the TV setup menu, perform a digital cable search. This is a separate operation from the full channel scan. The TV manual says this may take up to 10 minutes, so be patient. The set should find the channels on your system. When you want to watch TV, press the INPUT button on your remote to select Digital RF as the source. Press INPUT again to select any other source (DVD, etc.) you have connected when you want to watch that.
I was wrong about needing a converter. This TV has a tuner that can pick up the cable channels if they use a system called QAM. Verizon says QAM-capable sets don't need a box for non-scrambled or premium channel, so you should be good once you have the TV scan channels.
I couldn't find the DP26648 manual at Sanyo's site, so my solution is based on the DP26647 manual. They should be similar. You can download the manual here if you don't have the manual for your set.
Apr 01, 2009 | Sanyo DP26648-R 26 in. LCD TV
White screen
I called sanyo ,they had me try this and that and then said a tech guy would call back he did i am taking the tv to a repair shop and it will be fixd under the warranty.
Jan 11, 2009 | Sanyo DP23625 23 in. LCD Television
Set up lcd tv
Make sure of correct input
HDMI is best
cable box must be set to HDMI
otherwise input to channel 3
Jul 22, 2008 | Sanyo DP26746 26 in. LCD Television
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
