Question about IBM ThinkPad R32 2658 Notebook
ThinkPad R32 Overheating
My Thinkpad overheated so much that I believe it fried both my internal wireless card and a new PCI wireless card since they both no longer work. The left side of the laptop (where the fan is) always feels hot to the touch, I would say too much.
It there a way to know whether there is something loose inside the laptop, like a heatsink? I assume is not common for the R32 to fry the network card. Any help would be greatly appreciated
  • 1 more comment
  • DeZaelez May 21, 2008
    Thank for the quick response, however I believe that the fan still works as I can hear it come on -- and when the ceiling fan is on and I leave the window open on a cold day -- the fan actually stops, which means that the laptop "thinks" it is cold enough.
    What I suspect is that the heat is not being dissipated properly and even though the fan turns on, it does not cool it enough.
    Any ideas on how to check this?
    Thanks, I'll see what I can dig up.
    I thought I had ... sorry.
    Genius:
  • 1,027 Answers
If the internal wireless and pci are no longer working, see if any usb ports work as the usb and pci bus are configured by the same chipset
If the usb fails try the link below
. Try this link for all updates
To monitor temp try this
Posted on May 21, 2008
    President:
  • 2,712 Answers
Its more likely the fan has stopped working. I recommend taking it to a qualified repair shop.
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 21, 2008
    All I can come up with is that there could be some loose contact somewhere inside, since you said that the wireless card are fried as well..
    The only way to really determine the cause of the issue is to open it up and take a look for impropely fitted components, or cold solders..
  • Swilin Sampson
    You are welcome. However, I would appreciate it if you caould provide a more favourable rating..at least a Helpful
    Thanks for trying is a negative rating :)
  • Swilin Sampson
    Thanks..Please post back if you have any further queries and let me know how it goes..
Change os on a think pad r32
Seems you are attempting an upgrade install. Try to do an erase install / Format Install, most probably it will pick up the drivers on its own if not you can search for the drivers on
http://www.driversforfree.com/omn_ofm_omd/ibm/thinkpad/r32/drivers.aspx
Apr 04, 2014 | IBM ThinkPad R32 2658 Notebook
My thinkpad g40 has the following on my screen "resource conflict pci net controller in slot 01 bus :02,device:02,function:00 " how do i correct this?
Dear Friend,
This type of message is commonly associated with wireless or PCI card failures. I strongly suggest you to either update your BIOS (if you can) or disable this devises.
Another way to isolate the problem is to get an external wireless card or PCI network card.
Jul 22, 2011 | IBM ThinkPad G40 2384 Notebook
My laptop wont boot up. it only goes to the IBM screen and on the top it says error 1805 turn off and remove pci card. and if i go intothe diagnostic boot it says internal pci card shadowed and also says...
The POST error code 1805 for the ThinkPad is as follows :-
1805
Unauthorized Wireless USB card is plugged in—Power off and remove the Wireless USB card.
  1. Remove the Wireless USB card that you installed.
  2. System board.
Please click on this link for further POST error codes and explainations
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=ibm&lndocid=MIGR-42321&velxr-layout=print
Jul 03, 2010 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad R32 2658. USB recognizes devices but will not run them. Using a cardbus for now, but need that slot for wireless card soon. Is this a spendy fix?
Have you got SP3 installed from MS, if so what are the USB devices you are trying to run??
Do they have installtion driver disks?? If so you must install them BEFORE plugging the device in.
Do these devices show up in another PC???
Feb 11, 2010 | IBM ThinkPad R32 2658 Notebook
Wont connect to my wireless routerits a thinkpad 2658 with a built in wireless connector I have linksys router. 2.4 ghz wireless My other computers in the house can connect just fine
does it see the router?
does it try to connect and ask for the passphrase? It maybe it doesn't like the encryption. you may have to set the router to something simpler like 64bit wep
check what channel the router is on and what channel the wireless card is set to.
Jan 11, 2010 | IBM ThinkPad R32 2658 Notebook
Owners manual ibm thinkpad notebook 2568 r32?
Try this link. Its pretty long so make sure you copy the whole thing.
http://www-307.ibm.com/pc/support/site.wss/product.do?subcategoryind=0&familyind=101256&brandind=10&doccategoryind=0&modelind=0&doctypeind=8&validate=true&partnumberind=0&sitestyle=lenovo&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&operatingsystemind=49979&machineind=101260
Mar 20, 2009 | IBM ThinkPad R32 2658 Notebook
Thinkpad T23
I believe the T23 has a built in wireless slot located on the bottom under a panel. If so, you will need to purchase an internal wireless card and download the drivers for it. You can usually get a good deal on one at Ebay. Or, you can go to Walmart and buy a universal wireless card that slides into the bus port or usb port, depending on the card. Walmart sells universal wireless cards for anywhere from $25 to $125, depending on what you want. I suggest the $30 to $40 range, they will work fine for you.
Jul 05, 2008 | IBM ThinkPad T23 Notebook
How to run USB 2.0 version device on USB 1.0 port on IBM Thinkpad R32
Well i not shore what to do, but you can go to you local computer store or the IBM factory.
May 01, 2008 | IBM ThinkPad R32 2658 Notebook
DVD
I don't mean to disagree with my associate, but DVD players for R series (or T, A, etc) can be found for less than 20.00 US (Ebay is a good example)
For that matter, we've got at least a dozen at our shop which we sell for 25.00
Installation is very simple as well, just pop the old drive out, put the new drive in.
Good luck
Oct 30, 2007 | IBM ThinkPad R31 2657 Notebook
IBM ThinkPad R32 2658 Notebook Logo
158 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
