Question about GN Netcom GN 9120 Professional Headset
GN 9210 Headset can hear all but I can't be heard.......Wolfgang
Lost transmission and replaced and charged new battery for 6 hours.
I can hear everybody very well, but nobody can hear me.
Have you any advise if this can be fixed or if I have to buy a new
headset. (This happened twice now in this office)
Thank you......Wolfgang
  • sarahann Nov 25, 2008
    I have the same problem. I can hear others but they can't hear me. is there something I can do or do I need to replace the headset?
  • 4 Answers
SOURCE: WEP170 headset
I have found out, that you need to set the wep170 into a pairing mode Blue light is on all the time (not blinking). When switching on you have to hold the button as long as you get there. This part is missing in the czech manual.I do not kno how it is in other languages. Once you are there everything works normaly. The code is 0000. Try it.
Posted on Apr 18, 2008
SOURCE: GN Netcom GN 9120 - can't hear
Hi There, I had the same problem with a headset one of our call centre reps were using. It's usually due to some one fiddling with the button. I got it working by removing the battery from the headset then resinked the headset to the base unit. Hope it works for you
Posted on May 19, 2008
SOURCE: GN 9350 Wireless Headset doesn't ring on the headset when phone rings
It only picks up certain digital rings. I changed the ringer on my phone and had the same problem. To fix it, I had to plug in the little microphone that plugs into the handset lifter and place the mic over the ringer speaker. Now it works fine.
Posted on Mar 18, 2009
keekus
  • 83 Answers
SOURCE: Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Posted on Jul 20, 2009
SOURCE: GN 9350 Headset won't charge, blue light remains off
Unplug the unit, then take the ear piece and slide the battery off .... When you have the battery detached from the ear piece, wipe off the metal prongs, leave it off for a few minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the unit to be charged. That should take care of the issue.
Posted on Sep 16, 2009
When im using my netcom headset im able to hear my customers , but they are not able to hear me. What should I do?
If this is a new problem it could be a blocked or broken mucrophone. If it is new and you have never been able to be heard you may either have a faulty unit or perhaps your phone requires you to attach an amplifier between phone and headset. If you google telephone headset compatibility guide look up you phone make and model and see if an amplifier is required when using a corded headset
Aug 04, 2013 | GN Netcom GN 2000 Headset
The blue light on my base unit is on but the headset does not app
Unplug the unit -- Then grab the ear peice, and slide off the battery, wipe off the metal prongs ...leave apart for a couple minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the battery to charge. But this should solve your issue.
Aug 29, 2009 | GN Netcom GN 9350 Wireless Headset
Battery for GN9120 is not staying charged; what can I do?
Hi
The battery is no longer charging just like your car battery only lasts for so long and then dead no matter how long its been on charge
try and get replacement if not should think about a new headset
Steve
Aug 28, 2009 | GN Netcom GN 9120 Professional Headset
I have a gn9120 headset that i love. suddenly, callers are complaining that they can't hear me. Is there volume adjustment or is there a defect?
Volume adjustment is made by depressing the two + and - together until beep is heard
once beep is heard press the + button several times until louder bleep is heard this will increase transmission from headset and cure the problem
Steve
Jul 15, 2009 | GN Netcom GN 9120 Professional Headset
GN 9350 Headset won't charge, blue light remains off I tried the solution of placing the headset on the charging cradle, then pressing both phone/USB button simultaneously The headset light...
Jun 21, 2009 | GN Netcom GN 9350 Wireless Headset
Hi, We have a GN 6210 wireless headset and it doesn't seem to want to hold a charge anymore. It's good for about 1 hour and then starts beeping and goes out. Is there a battery or something that I need to...
When I used this model in the past, it appears that the battery wasn't holding a charge after a year of use. I called them about it and told me that the battery wouldn't hold a charge anymore, there wasn't a battery replacement for it, and that I would have to replace it.
I believe Jabra is currently doing the support for GN. Support can be reached at this link:
http://www.jabra.com/Sites/Jabra/na-us/pages/Support.aspx
Dec 02, 2008 | GN Netcom GN-6210 Consumer Headset
Jan 30, 2008 | GN Netcom GN 9120 Professional Headset
Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
Sep 01, 2007 | GN Netcom (9120-48) Wireless Headset
GN Netcom GN 9120 Professional Headset Logo
338 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
