IS this printer wired LAN to your router? If so, look in the settings to your printer and check the IP address.
Now in the settings menu, it should have an option for you to set DLNA or manual. Set to manual. Enter the same IP address the machine originally had. If you could not find what ip address your printer had, in windows startmenu find run or command prompt and type ipconfig all.
Find the ip address for your computer. Add 10 to it. For example, if it is 192.168.0.2 than give your printer 192.168.0.12 If it asks for a subnet mask use 255.255.255.0
I believe the problem you are having is that every time your router resets it gives your printer a different ip address (dynamic IP), so your printer driver software can no longer find it. You need to use a static ip address (manually giving the printer an ip address) so it never changes and the driver can always find it.
