Question about Car Audio & Video
Red wire i have a generic wiring harness for my 06 silverado. i wanna know where to wire the red wire. it is a seperate wire
  • 88 Answers
Your red wire is probably your ignition 12V, check on your harness if you you have a permanent 12V ( + Batt), if you didn't have a permanent 12V you have to connect your red wire to a permanent 12V or directly on your positive battery
hope this helps
sserpentio
Posted on May 22, 2008
I have the battery compartment wires connected correctly ( as per YouTube video) and the red lights work
Electrical: Circuits, Relays - SwedishBricks
www.swedishbricks.net/700900FAQ/Electrical-CircuitsRelays1.html
Electrical: Circuits, Wiring, Relays, Switches FAQ Home ... 3. Corroded harness connections cause most intermittent circuit failures. ... When they do fail, the failure will be predictable, such as a bad current or ground connection, blown fuse .... Here's a generic statement about your relay (which I know nothing about) -- this ...
GM Passlock Security Fix - Bergerweb.net
www.bergerweb.net/PasslockFix/
Mar 8, 2012 - This normally works! ... In GM cars, there is a bundle of three wireswhich go from the Body ... through a hole in the radio compartment toward the steering wheel. ... Find the three wires that connect the Passlock Sensor to the Body ... withblack fabric tape, unwrap them and separate the three wires so you ...
Jan 19, 2016 | Electrical Supplies
Installing aftermarket stereo in 99 silverado which wires from stock harness connest to aftermarket harness
connect the wires as indicated below
1999 Chevrolet Silverado C1500 Wiring, aftermarket stereo wire colors
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (Tape off) not used
Car Stereo Dimmer Wire: Brown (Tape off) not used
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
Oct 22, 2011 | 1999 Chevrolet Silverado 1500
2002 silverado 1500 wiring diagram where can i get a copy? i need to wire it for a trailer.
Look in your glove box and see if you have the PRO code U89: wiring harness, car trailer
It's common to have the trailer harness already installed in your Silverado without you know and the dealer can pull it out for you from where it's tucked up in the frame passenger side by the spare tire for the simple cost or $65.00.
http://www.etrailer.com/tv-wiring-install-2006-chevy-silverado.aspx
Thank you for using fixya and good luck.
Apr 27, 2010 | 2002 Chevrolet Silverado 1500
Were do you hook up the two wires under the hood for trailer brakes on a 2000 silverado
Sometime around 2000, GM started putting trailering pre-wire harnesses in the vehicle. Your truck may have this harness built in and would greatly simplify brake controller installation. Look under the glovebox and see if there is a wire harness tied off. There will be four wires in this harness, which should be run over to the steering column to use it. Most trailer brake controllers are compatible with this harness.
The four wires in the harness are: Red, 12vdc; black, ground; blue or purple, brake pedal; and brown or white, trailer brake wire to seven pin, four pin, or five pin connector at trailer hitch, if your truck came from the factory with a trailer hitch.
If you are adding the hitch and do not have the four wire harness, the under hood wires from your brake controller are Red, connect to one of the studs under the distribution box cover (the distribution box is on the driver's side against the firewall. Underneath the cover are two large threaded studs which are hot from the battery all the time); and the other wire from your brake controller would have to be run the length of the truck along the frame, tied off in several places, to the trailer hitch connector on the bumper. Follow the directions that came with trailer hitch wiring connector to connect this wire to the proper pin in the connector.
If this has helped you, great, and please remember to vote/comment.
Feb 21, 2010 | 2000 Chevrolet Silverado 1500
I need to know the colors and purpose of my 2000 chevy silverado 1500 5 wires for the trailer harness
off the top of my head international standard
RED STOP
GREEN RIGHT HAND FLASHER
YELLOW LEFT FLASHER
BROWN SIDE /TAIL LIGHTS
WHITE EARTH
BLUE AUXILIARY
BROWN PARK /TAIL LIGHTS
Nov 10, 2009 | 2000 Chevrolet Silverado 1500
2006 Silverado Slide-in camper harness --- No power --- Do I need to plug it in somewhere under the dash? I want to use the 12vdc and ground to power a sprayer tank but when I unwrapped the harness I don't...
there is a red or red with black trace wire under the hood near the fuse box, it will be taped to the harness. that wire needs to be connected to one of the power studs on the fuse block. you may also have to install a j case fuse into the fuse block for it.
Jul 07, 2009 | 2006 Chevrolet Silverado 1500 2WD
97 color scheme for aux hok up
I could go outside and pop my dash apart real quick and tell you.Its real easy to take it off and pull the cd player and radio right out.Is your wiring harness missing or something?Is that why you need to know what it looks like?
Nov 23, 2008 | 1997 Chevrolet K1500
Radio codes
Battery WHITE/YELLOW (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
RF Speaker (-) BROWN
LR Speaker (+) RED
LR Speaker (-) GREEN
RR Speaker (+) BLUE
RR Speaker (-) BLACK
Oct 18, 2008 | 2003 Chevrolet Silverado 1500
Wiring diagram
Battery LIGHT GREEN (+)
Accesory BROWN (+) RADIO HARNESS
Illumination DARK GREEN/WHITE (+) RADIO HARNESS
Dimmer DARK GREEN/BLACK (+) RADIO HARNESS
LF Speaker (+) GREEN/RED
LF Speaker (-) LIGHT GREEN/WHITE
RF Speaker (+) RED/BLUE
RF Speaker (-) LIGHT GREEN/BLACK
LR Speaker (+) YELLOW/WHITE
LR Speaker (-) YELLOW/BLUE
RR Speaker (+) GREEN
RR Speaker (-) GREEN/BLUE
Jul 13, 2008 | 2006 Chevrolet Silverado 1500 2WD
Rockwood detanater amp225 wiring harness
I'm guessing here, but power is usually a red, thick wire. seldom yellow ( old Pioneer)
Ground Is usually a thick black wire.
Amp turn on blue.(thin)
If it isn't, it ought to be.
If in doubt don't try it , check with a installer.
Fuse at battery!!!!!
Sumthin
May 27, 2008 | Car Audio & Video
Car Audio & Video Logo
116 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
