Question about SanDisk Sansa e250 MP3 Player
Sansa e280 Still not recognized after reinstalling the media converter. I also uninstalled from device manager under disc drives. Getting really frustrated with this. I have Windows Vista with WMP11. This was working before I got stuck on refresh database and had to update my firmware. Help!
  • busa_joe May 22, 2008
    My e280 is already formatted.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
This is a common problem usually formating your sansa can solve it.
Give it a shot and let me know.
Posted on May 22, 2008
Sansa e280 won't upload my photos. Do I need media manager or something?
You need to use the Sansa Media Converter to convert pictures to a format the Sansa can handle. They also need to go into the internal memory, as the e280 will not display pictures from a microSD card.
Apr 26, 2010 | SanDisk Sansa E280 MP3 Player
My Sansa e280 will is not being recognized by any PC in MTP or MSC mode. Windows XP is operating system.
i would suggest reinstalling the device or removing the device and letting the computer restart to see if that works if that dont work then use the CD that came with the device finally if that dont work contact Customer Support and see if that helps =)
Sep 02, 2009 | SanDisk Sansa E280 MP3 Player
My sansa media converter did not detect my sansa e280
Set the device to MSC mode (default is Auto) in the USB properties on the Sansa device. This worked for me with a Sansa Fuze on Windows XP running Sansa Media Converter 1.0. Hope this helps.
Jul 17, 2008 | Audio Players & Recorders
Media Converter not converting......
Ok I've got my e280 and I wanna see some videos. I've got some random videos on my hard drive to see and whatnot, yea... So I get the Media Converter thing installed and it recognizes my player and all, but when I tell it to convert a video, it simply comes up with a message saying something like this below...
Finished Files: 0
Unfinished Files: 1
Reasons for Failure:
And no there are not any reasons listed. It just is really annoying and I need help
May 02, 2008 | SanDisk Sansa E280 MP3 Player
Media converter
The reason it says connect a device is because your device is not been recognize by windows properly..
What i would recommend you to do is to uninstall the device and reinstall it back...tou uninstall it...assuming that you are running windows xp1.gif...click on start, right click on my computer and go to properties..you should have your system1.gif properties open then click under hardware1.gif then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives1.gif and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer and check to usb mode..it has to be under MTP mode or auto....after you check the mode open up your windows media1.gif player click on tools, options and click under privacy...clear the history4.gif and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..Follow the link below to obtain the driver for your device..Select your device model and operating system1.gif.....
http://www.sandisk.com/DriverDownload/index.asp
I hope4.gif this helps4.gif..
Please rate accordingly
Thank you
Computerrep
Mar 26, 2008 | SanDisk Sansa e250 MP3 Player
I had this same problem
What i did was go to an other computer and poped in the cd for sansa media converter and downloaded it.
If that dont work go to my computer and click on sansa e280 and format it.NOTE: this will delete EVREYTHING>
I hope it helps
Mar 19, 2008 | SanDisk Sansa E280 MP3 Player
Sansa trouble recognizing/ synching
What i would recommend you to do is to uninstall the device and reinstall it back...tou uninstall it...assuming that you are running windows xp1.gif...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives1.gif and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer and check to usb mode..it has to be under MTP mode or auto....after you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..let me know the outcome...
Jan 22, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Samsung YP-T9J MP3 Player
What i would recommend you to do is to uninstall the device and reinstall it back...tou uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer and check to usb mode..it has to be under MTP mode or auto....after you check the mode open up your windows media player1.gif click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media5.gif player to 11 even though you have done that already..let me know the outcome...
Thank you
Computerrep
Jan 21, 2008 | SanDisk Sansa E280 MP3 Player
you can copy from the my computer open the my computer - open ur device - copy ur images but i am not sure about the videos sorry !!!!
Jan 12, 2008 | SanDisk Sansa E280 MP3 Player
I can't download music onto my sansa,my computer is saying device not connected!!!
What i would recomend you to do is to go under device manager to see if the device is recognize...you can open your device manager by click on start,run and type devmgmt.msc...that will open your device manager...check under hard drive, portable devices or universal bus serial controller...once found the device right click on it and uninstall it..once you do that....unplug the device and plug it back into a 2.0 usb port..after that windows should recognize your device...
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
