Question about Dryers
Frigidaire dryer thermal limiter keeps tripping. dryer is 9yrs old and first occurance happend 4 months ago. replaced limiter myself and it lasted 3 months. replaced again today and it blew on first load. is it a faulty limiter or is something else causing the problem?
    President:
  • 1,314 Answers
There are several issues that can cause this most common is the vent restricted backing up heat in the dryer if its as old as you say you need to check the whole vent system it has to be 4inches dia all the way if its mashed or drooping under the house its restricted if its folded over or mashed behind the dryer its restricted the thermal limiter is a safety thermostat it opens about 300 degrees to prevent fire the dryer has three thermostats an operating thermostat a safety thermostat and the thermal limiter if the operating thermostat fails then the safety thermostat takes over and cycles on about 165 on and off if both thermostats fail then the thermal limiter opens about 220-300 depending and it doesn't reset and cuts all the power to the dryer till a tech can check everything i just told you about so if your vent is clear and the best way to vent is 4inch pvc drain pipe 90 it up behind the drier then connect with a short peice of metel vent then just replace all three thermostats
Posted on May 21, 2008
I have power but the motor don,t start all the lights come on
Posted on Oct 13, 2008
    Genius:
  • 1,073 Answers
Check the vent to make sure that it is not obstructed
check the frount panel of the dryer, disasemble it to make sure that there is no lint inside the filter housing
check the foam seal arround the blower housing
check the blower wheel to see it is not striped
chek the door seal for a tear
operating thermastat kiking off right
most of the time the issue with the limit blowing is a venting problem i would go there first
Dryer has power wont start
Hello Dom - Being that you have narrow down some possibilities, here are a few simple troubleshooting tips that may help you get to the root cause:
1. Make sure the dryer is plugged into outlet, and plugged in correctly.
2. Is house fuse blown or circuit breaker tripped? Replace fuse or re-set circuit breaker.
3. Make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. I would recommend reaching out to a Licensed Electrician check to make sure it is on a circuit by itself.
4. Thermal limiter tripped or an internal problem with the dryer. A thermal limiter automatically turns off the motor (electric dryers only) in the unlikely event of an overheated situation.A service technician must replace the thermal limiter after correcting the fault.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Jun 19, 2013 | Frigidaire Dryers
I have a FDE336re2 frigidaire dryer. I have replaced 3 thermal limiter switches and the 3204267 Frigidaire Dryer Safety Thermostat. The exhaust is clear. I operated the machine with the entire top lid...
Try running the dryer with out the vent hose connected see if the problem persists. This will eliminate the ventilation system of your home from the equation. Then if problem persists must gointo the dryer.
Dec 11, 2012 | Frigidaire FDE336RE Dryer
Frigidaire electric dryer model gleq2152es1 lights wont turn on and wont do anything
Hi ana piedranayari05, this is AP! Thank you for your post
I understand you are having trouble with your Frigidaire electric dryer not turning on. Make sure the dryer is still plugged into the outlet, and plugged in correctly. Also check to see if the house fuse is blown or circuit breaker tripped? If so, Replace fuse or re-set circuit breaker. Check to make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. Have a licensed electrician check to make sure it is on a circuit by itself. Additionally, the thermal limiter could have tripped or possibly an internal problem with the dryer. A thermal limiter automatically turns off the motor in the unlikely event of an overheated situation. A service technician must replace the thermal limiter after correcting the fault. If you have check the plug, fuses, and circuit breaker and still no power I would recommend contacting a local technician to diagnose and service your electric dryer.
Jan 18, 2012 | Frigidaire GLEQ2152ES Electric Dryer
I have a sears dryer 417.90802990 which heats up but will not run..we had this problem before and replaced the themal limiter and it worked fine for about 1 month..same problem..replaced the thermal...
check that the intake air vents are clear it must be able to breath freely and that the hot air can get away freely this is the most comon thing to pop the thermal limiter,,the only other part that will blow the limiter is the heating coils if they are geting to hot becouse of a short in a winding
Jul 08, 2010 | Dryers
My dryer will run but will not get hot. The trouble shooting guide says that on of the two house fuses in the circuit may be blown or the thermal limiter is tripped. Where are the fuses in the dryer. I...
First id make sure you have both phase of AC power coming into dryer.
Go to your house panel and reset yoru house breaker for the dryer. If in the USA the breaker should be a 240volt / 30amp breaker. It will have two breakers tied together at the trip switch.
If AC power is good at the dryer outlet then it could be one of the followings.
  1. Open Thermal limit fuse or trip switch.
  2. Open Heater Element.
  3. Control board is faulty.
Oct 26, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Thermal limiter stops dryer; replaced multiple times. Dryer dead.
I think you are working on the wrong end. Check the fan and inlet ductwork of the dryer, if the air isn't moving properly, it will not move enough to keep the coils and limiters cool and they will fail after working properly a few times.
Sep 03, 2009 | Frigidaire Dryers
Thermal Limiter
The belt on the drum my be broke
Aug 04, 2009 | Frigidaire Electric Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
My frigidaire dryer only blows cold air
You either have a tripped safety switch, a burnt element, or a burnt/loose wire to/from the element and or safety switches/controlls.
If you are handy, and have the tools, it should be a fairly easy repair.
You will need a volt/ohm meter to check the element for continuity, the safelty limit switches for continuity to lacate which part is the problem. (some switches are push button resset, some are one time trip and must be replaced.
The second issue is what caused it to quit in the first place.
The #1 cause for that type of failure, is lack of airflow due to a clogged vent pipe.
Make sure the filter, dryer outlet, pipt and outlet from the house is all clear from lint, birds nests, kinks etc.
Jan 16, 2009 | Frigidaire FEQ332E Electric Dryer
Runs but no heat
i have replaced TH2 in my dle0322 about 6 times now. It never lasts more than a month. What could be causing this?
Apr 21, 2008 | LG DLE2532W Electric Dryer
Dryers Logo
259 people viewed this question
Top Dryers Experts
