Question about Canon Office Equipment & Supplies
Check Paper size, change paper size casette LTR
  • 1 more comment
  • read_07 Jun 03, 2008
    check paper size
  • Anonymous Jun 29, 2008
    I have the same problem.
    How do you fix this ?
  • masrooradil Jul 17, 2008
    printer is giving an error check paper size
    cassete change =LTR
It seemed to work, It began after I downloaded a document from the Russian government and translated it in Google.
Posted on Feb 13, 2009
Fisr chage your printer settings or preferences to whatever paper you are using in your computer, to A4 or letter or which ever paper you are using, after that you have to erase the jobs on your printer thats why it keeps printing the same document. Here is how you do that.
Step 1 – Remove jobs from the Print Queue
  1. Press the Status Monitor button (button 11)
  2. Press the left or right arrows to select PRINT STATUS
  3. Press OK
  4. Press OK to delete the Print Job
    Note: If there is no job, NO PRINT JOB EXISTS is displayed
  5. Select YES to confirm deleting the job.
After this you chould be clear to print anyother document.
Posted on Jul 25, 2008
Paper keeps jamming
I would look to see if the paper tray's Dials are set to the correct paper size as the paper in the paper tray.. LTR size set to LTR or LTR-R set to LTR-R if the dial is set to the wrong size the copier will jam all the time. Due to a timing issue, the copier thinks it has one size, but actually is try to make a copy on different size... Good Luck
Jun 08, 2012 | Canon imageRunner C3100N Copier
Whenever I try to print anything or copy anything on the Cannon MF6530 it will print the first page then make a beeping noise and the red light starts flashing and it says change paper size - casette 1 LTR...
try to set the proper size for the paper in the printer.
press [Additional Functions] button (right of the LED display)
navigate to Common Settings
use [<-] and [+>] buttons to navigate to Select Paper Type and press and press OK
Confirm that Cassette 1 i selected (or Cassette 2 if you have optional installed)
and Set the paper type
next navigate to Reg. Paper Size, press OK, confirm again the cassette (1 or 2) and using the arrow buttons, set the paper size (should be LTR if you using LTR)
Sep 20, 2011 | Office Equipment & Supplies
My Cannon ImageRUNNER 2270 is not printing the entire page. It is cutting off the top quarter of the page. I have changed the margin settings and it is not doing anything different.
Check to make sure that the paper size dial on the paper cassette is the same as the paper size in the cassette. Portrait or landscape? I don't know whether you use American sized paper but the dial Must be LTR ( front to rear orientation of paper ) or LTR-R ( Left to right orientation ). I know of no other reason for the problem.
Jun 19, 2011 | Canon imageRUNNER 2270 Copier
I have a canon 4350d printer when i give print it asking for current paper size in every print
you can define this size in it's driver property,,,,( settings--printer and faxes--canon--properties)
Apr 27, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Message Display on LCD of machine it,s load paper LTR
It means that you under printer properties/preferences - custom paper size have ltr size as your default, change it in desired size, eg. A4.
Then turn off and on the copier.
Or check the sensor position on your drawer. blue rail with triangle that must be on A4 or A3 depends on paper that you have in drawer.
Feb 10, 2010 | Canon iR 2022 Printer
My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
INCORRECT PAPER SIZE TRAY: LTR
Hi mate ,
Prior to your issue that cassette size incorrect.
1)chk your device casette ,any size selector ?put it to the correct size.
2)It actually located at the cassette itself.
3)or u can chk at the add func key>custom setting>input correct size>register the size
Good luck mate ,pls feedback to me if there is any query ,i need to know u using wat model.Cos i can give u more detail solution.
PLs rate me !!!!!!Thanks
Oct 16, 2009 | Canon Office Equipment & Supplies
Check paper size
Change the default setting for the paper size on your computer to letter. The paper size need to match on the printer and computer for it to work properly.
Apr 13, 2009 | Canon MF3110 All-In-One Laser Printer
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
Asking to change paper size.
yo tengo el mismo problema
y cada ves que cargo papel en el caset, sale una impresión de prueba
Jun 03, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
1,053 people viewed this question
old marine
old marine
