SU G 95 MANUAL
CAN SOME HELP ME WITH THE MANUAL FOR SU G95 TO HOOK UP MY TV .FORGOT HOW IT WAS DONE BEFORE AND THE HOOK UP I TRIED WONT GIVE SURROUND SOUND EFFECT
    Genius:
  • 1,550 Answers
Go to http;//audio.manualsonline.com maybe there you find it.Good luck.
Posted on May 25, 2008
Need help with part numbers for replacement
values of D731,D732,Q733,Q732,Q735 and Q737
Q733 = 2SB321AQSTA
Q735 = Q737 = 2SA992EFPTA
Q732 = Q733 = 2SC3311AIRTA
D731 = MA436MTA
D732 = MA165
Sep 30, 2012 | Audio Players & Recorders
I'm trying to hook up a sharp aquos tv to an rca surround sound receiver and it won't work? any suggestions? I have tried turning off the speakers on the tv....
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
May 23, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Any extra remotes??
No other remote control will work with this set. You must have its original remote control. Contact the nearest Technics authorised service center for details.
Mar 30, 2012 | Televison & Video
My su-g95 technics Stereo integrated amplifier wont play any noise. and when i adjust the volume it makes a popping/crackling noise. i am 100% sure all the speakers were hooked up correctly.
Well it sounds like your amplifier IC's are working correctly since you are hearing that pop. I have the same amplifier and every 10db increment it pops. Have you tried every input? Possibly try starting at a low volume, plug an RCA plug into CD or any other input, and touch the center prong of the other end of the cable. You should get a 60hz hum if your in the USA, otherwise it will be 50-55hz. Regardless it should make noise.
Sep 29, 2011 | Technics SUV500 2-Channel Amplifier
Technics SU-G95 Amplifier and no sound on left speakers
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Dan
Mar 14, 2010 | Technics Audio Players & Recorders
No audio
went into setup, tv and kept hitting the mute then unmute it finally took. Not sure what was wrong with it since I had already done that several times. The two audio outputs on the side of the tv do not work like it says in the manual for surround sound. Its definitely a cheap tv.
Jun 21, 2009 | Olevia 227-S11 27 in. LCD TV
Where do i plug in to here my TV on my HtS3544
TV Audio Out RCA cables to Receiver's TV Audio IN
Apr 07, 2009 | Philips HTS3544/37 Theater System
No surround sound on ps3
Set the sound out put on ps3 to the optical out put then set sound on ps3 to give you dolby digital,dts,aac etc.
PS, do not set the hrtz range above 100 as this can damage your speakers.
hope this helps.
CABLE GUY.
Jan 05, 2009 | Onkyo HT-SR800 System
Hooking up new tv to surround sound
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Feb 17, 2008 | Vizio VX32L Television
169 people viewed this question
 Grubhead
Grubhead
