HP printer I have had people tell me that HP is better, I currently have everyhing on mine but a fax and would like to keep those features.
  • 3,037 Answers
Yeah, basically go to a Best Buy, Circuit City, or any Office Supplies Store and tell them you want a HP Inkjet Printer with all of those features and then you can choose between them. I don't know what you price range may be, but they are all basically the same. If you want better print quality or anything, let the salesperson know and they should be able to direct you to what you want but I think you are just looking for the basic printer.
Look for an HP OfficeJet All-In-One Inkjet Printer is basically what I am saying. Any of them should do for you. We own a 4300 series which has never had any problems. good luck and let me know if you need anything else
Posted on May 21, 2008
I have an HP Officejet 6500A plus. Sometimes when I attempt to print a document, instead of printing, the Send Fax window opens. What causes this and how can I fix it?
This is the PC fax facility, unless until you entered the fax number job wont go any ware,,.PC fax facility is very good feature that with out document you can type and send the faxes through this facility as well as your files..Better to rename the drivers as "fax" to avoid confusion...
Dec 23, 2011 | Office Equipment & Supplies
I just bought a new computer. Someone assisted me in connecting the computer and my HP Officejet 4215v all-in-one. We were unable to install using the cd so we went online. My problem is that the scan...
For scanning you may have to go to, find your model and they have a manual that you can go to to get the information. It will tell you what to do. I had to same problem, printer on the front was telling me that I did not have that feature. HP has good technical help and support, so you can to that section in HP. If you have another program on your computer, such as Microsoft Publisher, or any other program that you can use for scanning, use that and don't worry about the HP.
On the fax, do you have a telephone attached. If not, you would have to attach your phone to it; the only problem is when you are using the fax, no one can reach you on your phone, unless to get a separate phone to handle it. I use to have a separate phone, using a student line with the telephone company, but that was extra money. If I need to fax, I just go to an outside fax place.
Jul 13, 2011 | HP Officejet 4215v All-in-One Printer
We keep receiving a T.30 Protocol Trace Report with the "Type: Receive" and "Result: Communication Error (17)". How do we figure out what this means? Thnaks.
If this is printing out and consuming a lot of paper it can get annoying. This report is intended for a technician to trace problems with your machine. The report basically tells you that your fax attempt failed and gives all the technical settings. To the average user this is meaningless. The print feature for this is normally turned off, but I have seen a few cases where the default was set to print. Under the diagnostics menu, find the T-30 error setting and set it to never. Check the firware on your printer to make sure it is current. Print the configuration page and check the firmware version on the front page. The current version is 48.181.8. There are many modem fixes included with the firmware.
May 23, 2011 | HP® LaserJet M5035 MFP Laser...
When using scan feature in my HP 7680 printer any document I scan never scans to its original size, it always shrinks by at least 30%; how can I scan documents to original size?
Try checking your setting. press scan menu (over by the fax buttons) then choose paper size. you may have it on a smaller size. i have mine on automatic. See if that works.
Aug 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
Problem for HP Officejet 7130 All-In-One InkJet Printer tells me to close ink cartidge and its CLOSED! Thanks
The full-featured HP OfficeJet 7130 all-in-one offers photo printing, double-sided printing, an automatic document feeder (ADF), a fax, a scanner, a copier, and inputs for all of the current breeds of photo memory cards on the market today. At first blush, the machine's large footprint may seem overbearing--until you take into account just how much space you're saving by putting all of your technological eggs into one basket. Unfortunately, the 7130 isn'
Jul 16, 2010 | HP Officejet 7130 All-In-One InkJet...
My HP6110xi All-In-One doesn't want to scan
First, scans and copies don't really use the computer. Can you print a document from your printer. If not, then your problem is within the computer.
If it does print then....
Try using the scan feature within the HP solution center. It works on mine but the scan button on the printer does. Also some art programs have and "ACQUIRE" feature under file to scan with. (Sometimes called TWAIN.)
Hope this helps, so you can start scanning.
good luck
Feb 21, 2010 | HP OfficeJet 6110xi All-In-One Thermal...
Off hook message
Make sure you are plugged into the LINE port and you are not sharing the phone line with a computer.
Sep 25, 2008 | HP 920 Plain Paper Fax
Hi red,
You may need to set the fax as the default answerer of incoming calls. Here's a little tip, most local phone companies offer a distintive ring feature that only the fax will answer. If you get the option your users manual will tell you how to set up this feature and whats neat about is you get a seperate
number for that feature, your own dedicated fax line without add any extra outside lines.
Aug 17, 2008 | HP Officejet 4110 All-In-One InkJet...
37 people viewed this question
