Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
Abnormal Screen Color/Resolution
I bought a Westinghouse LTV-40w1 HDC 40.02 in. HDTV LCD TV/DVD Combo about 1.5 years ago from Best Buy. Everything worked fine until it was disconnected it and gently moved the TV to another room while we painted. When we re-installed and turned on the screen image contains abnormal colors. A lot of blues and pinks. Have tried adjusting all differnt combinations of screen settings, (brightness, contrast, etc.) and nothing works. The abnormal screen colors happen with both cable and DVD. Is this economically repairable? Thanks!
  • 1 more comment
  • random99 May 23, 2008
    Is there another potential solution? Speakers are not hooked up. I shut down for 45 minuts and turned back on but problem persists.
    Do you know potential faults? THanks
    Speakers were not plugged in but I moved them away from TV. I turned off TV for about 45 minutes and turned it back on and problem persists. Could cable box or cable phone receiveer stored nearby also contribute to problem? Thanks
    President:
  • 2,712 Answers
It seems more a problem due to an external electromagnetic field. You can try using a degaussing wand, or try to realign the position of the TV.
Try removing any sources of electromagnetic radiation away from the TV. These include magnets (Speakers have magnets) and radios, etc.
You can even try a hard reset..unplug from wall and cables, wait about 15 minutes and replug.
Hope that helps! Should you have any further questions, please post them here.
If you are satisfied with my solution or have no further queries, please take a moment to "Accept" this solution.
Thank you for using Fixya!
Cheers!
IrishDruid
Posted on May 22, 2008
  • Swilin Sampson
    Swilin Sampson May 22, 2008
    This article also may prove useful..
  • Swilin Sampson
    Swilin Sampson May 23, 2008
    Well, if the degaussing did not work, it could be one of the smaller components on the main board that could be faulty. It is difficult to say exactly which, without performing any tests . However, the defective capacitors should be easy enough to identify. Their caps (tops) will be swollen and bulging. Here is a sample pic:
    The resistors are a bit more difficult and cannot be identified without an ohmeter.
    In any case, should the degaussing not work, I recommend getting a qualified technician to take a look. If the fault is just with the capacitors/resistors, then repair should easily be under $100. However, if one of the larger components are faulty (which I doubt), then the cost can go up likewise.
    Please check with Best Buy first, if your TV is still under warranty, cause this would definitely be covered by warranty.
    Hope that helps!
    Genius:
  • 2,785 Answers
It depends on the fault, it seems it will be good if you go for repair
  • 1,512 Answers
It has a magnetic feild nearby
  • Graeme Ross
    Graeme Ross May 22, 2008
    If you turn it off at the wall and leave for about 20 mins, then turn it onn again, it should DeGauss and reset the magnetic feild about the picture tube. If you have HiFi stereo speaker nearby, they too will create the colour impurities that you mention. Remeber, it is an external magnetic feild that causes the problem, so be aware of where they may be in relation to your television.
    regards
    robotek
Blue screen, no picture, audio works fine. TV
I have the same issue. I am thinking I need to replace the T-con board. Did you get your fixed and what did you need or do?
Oct 01, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
I get no picture ...tv turns on bulbs are working but I get no pic with tv or dvd and I cant see the menu or any of its properties .... but I do get sound, Thanks. The lcd tv is a westinghouse 40 inch dvd...
You need a T-con Board and I have that one for $80.00.
I reclaim working components for TV damaged in shipping or returned for other reasons. Simple repair for any body with a Philips screwdriver. NO special tools needed.
GBC_CMC@yahoo.com
Jul 11, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
40" Westinghouse LTV-40W1 HDC
GBC_CMC@yahoo.com
Apr 11, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Westinghouse DVD/TV combo has no sound
i'm sorry i didn't notice the "dvd/tv combo". the dvd mech inside the tv will need to be replaced.
Jan 21, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Dim backround and display on westinghouse LTV-40w1 HDC tv
u will have to go into service menu to set sub brightness be carefull u may do more bad than good write down all valus before atempting to adj.
Dec 08, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Westinghouse 42 inch lcd flat screen tv
only get sound from my 42 lcd screen fro westinghouse, no display
Jul 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Westinghouse TV
Hi Patty Jo,
I would suggest calling 1-888-Best Buy™ or 1-866-287-5555 for Westinghouse Support. Typically televisions become an in-home serviceable item near the 25-40 inch range.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 11, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Westinghouse LTV-40w1 HDC HAVE SOUND - NO PICTURE
GBC_CMC@yahoo.com
Jan 01, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Remote control
need to set up a remote control to my tv. I lost instructions and codes.
Nov 11, 2007 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Televison & Video Logo
190 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
