Question about Royal Office Equipment & Supplies
Royal ribbon glitch
Hi --
I have a restored Royal from around the 1950s. I love it! It's been working fine, but after a cross-country move it's been having a problem with the ribbon. The ink distribution very uneven. I notice there are some levers that seem to reverse the direction, but can't figure out if or how this will help me.
Can you help??
  • 478 Answers
Watch the ribbon spools as you type to see if they are turning.
Posted on Jun 04, 2008
My Royal Alpha 2001 ribbon stays stuck in high position a lot. How do I fix it?
It looks like it is not threaded correctly ribbon needs to be behind then in front of the carrier.
Aug 23, 2015 | Royal Office Equipment & Supplies
How to get into Royal 310PD calculator to change the ribbon
Good morning Norma.
Some searching about suggests this system has been around for a while. The Royal website has the ribbon at
royalsupplies com Looking a bit further, their collections of manuals doesn't include the 310PD, but the site says that if your product isn't listed, to call their help line at 888-261-4555. This is likely your best bet for finding some assistance from people who know the product.
Hoping that helps, and good luck!
Aug 20, 2015 | Royal Office Equipment & Supplies
My vintage Royal manual ribbon cartridge does not advance when typing., stuck in same position.
Usually lubriction, there are small pawls or teeth that move gears and pegs that fit into the ribbon. make sure you have the correct ribbon.
Oct 07, 2014 | Royal Office Equipment & Supplies
Need basket 4 rl170mx shredder
Give Royal a call at 1-800-524-0799 for parts.
Jul 31, 2010 | Royal 150MX Cross-Cut Shredder
Ribbon will not advance
mark the ribbon where it turns, where there is a pin of the typewriter passing through the ribbon,mark it with a white marker.
and type something, if it doesnt turn, you know the machine has a problem.
or try everytime pressing on the ribbon, if it works you know the ribbon is coming up, check if the correction ribbon is placed good.behind the correctable ribbon.
Feb 17, 2010 | Royal Office Equipment & Supplies
The ribbon wont advance
The ribbon drive on this model are gear driven..a .may be off, a loose set screw on one of the gears..the ribbon may be the wrong one or it has a ribbon reverse lever on the side of the machine, this should be free of binds.
Hope this helps........
Oct 07, 2009 | Royal Office Equipment & Supplies
How to load ribbon and rewind ribbon.
The ribbon should reverse itself if it working properly. Just to the indide of each ribbon is a reversing that the ribbon should go thru, Move that arm away from the empty spool and type a few letters it should reverse. DickyO
May 31, 2009 | Royal Office Equipment & Supplies
Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Apr 09, 2008 | Office Equipment & Supplies
Adler royal satellite 40 ribbon drive problem
Try holding the code key down and pressing the (.) period key. It is probably in the mullti strike ribbon mode.
Oct 18, 2007 | Royal Satellite 40 Typewriter
83 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
