Question about Philips Magnavox 27MS343S 27" TV
Magnavox 32MF231D I have sound but no picture on this unit. I took the back off I cannot find the back light inverter board. I've checked on E-bay, but don't see that board in my unit. The part # on E-bay is 6632L-0272A, I'm not sure if that is the same part. Can you help? Thanks.
  • philv29 Jan 05, 2009
    Magnavox 32MF231D.
    These are the numbers form this back light inverter
    board, CPT 320WA01C Rev 01.
    VIT 68001.70 LOGAH REV.3. Hope this helps.
    Thanks.
  • Eric Fay
    Eric Fay May 11, 2010
    Please submit me the model number for your tv. the backlight you found on ebay is for a 32mf231d37.
After 20mins the tv shuts off and then come right back on continously.....
Posted on Dec 21, 2009
Lg tv no picture but sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 07, 2016 | LG 47" 5700 Series LED HDTV - 47LN5700
I have a Polaroid 40gsr3000 40 in lcd tv. sound works no picture. think maybe inverter board. One board in middle of back .one long strip board that runs along bottom of tv. Is this inverter board?
What you have is an led tv . And the inverter for the back light led is there in the main board (mother board.) of the tv. Its no a separate board.
The the Log board you see is the TCON board which drives the led panel.
If you wish replace the inverter the you have to bay new mother board for you tv. In the model you have Almost every thing is integrated to the mother board like power supply ,back light inverter board the cpu section.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Dec 30, 2015 | Polaroid Televison & Video
Power light is on but no picture or sound and screen flashes
The most common cause of this issue is a failure of the filter capacitors on the power supply board. The board is repairable by replacing the bad capacitors. This will require a little soldering but should only take about 20 minutes total time. Here is a link to a repair kit with the correct capacitors \for that model.
http://www.ccl-la.com/catalog/product_info.php?products_id=323
Mar 23, 2013 | Magnavox 32mf231d
32mf231d Has no picture but menu works
Main board...or do a hard reset and that may fix it, you will need to do some digging to get instructions on a hard reset for your set.
Dec 10, 2017 | Magnavox 32mf231d
Our three year old philips tv, when first turned has a very dark, red, purple screen and after about an hour a normal picture appears. Advice please?
Hello cjjones1955,
Welcome, and thank you for using FixYa!
To answer your question: Your Inverter Board that controls the back-light bulbs is dying out.
I have included a link below, to eBay! so that you can see what it looks like, and purchase one, if you want this unit repaired.
Back-Light Inverter Board
http://www.ebay.com/itm/Philips-32MF231D-Inverter-320WA01C-VIT68001-70-3-/280735450669?pt=LH_DefaultDomain_0&hash=item415d23062d
Have a great day!
Sep 12, 2011 | Philips 32MF231D Television
I have a 32" Magnavox tv purchased in 2005, model
dear User,
pls be informed that supply capacitor are weak.
kindly change the supply capacitor
Feb 26, 2011 | Philips 32MF231D Television
Power light flashes but TV does not come on: no picture no sound. 34" HD Magnavox 32MF231D/37
Check if it the picture may be just faint. If it is it may be a bad ballast or weak back light. If there is none at all, it may be a problem with the power supply. This is the first circuit after the power chord. There may be loose connections, leaking or swollen capacitors or burnt resistors or the IC or the entire circuit may be bad. This is a common issue with these type of devices. While at it check the rest of the circuit for the same items. There are cases where the problem is with the main board.
Dec 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Magnavox 27MS343S 27" TV Logo
235 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
