Question about Disney DTD1363-CAR 13" TV/DVD
More help needed
Jaime, I replaced the p5nk50zfp regulator. The fuse does not blow any more but the tv still inop. I rechecked the regulator I installed and this one went open. Installed another regulator but TV is still inop. Any ideas? I don't have a diagram so pinpointing is tough. If possible give part # if have any ideas what may be.
Thanks, Jeff
  • Anonymous Apr 10, 2009
    It is blowing that regulator evertime I replace it..I will ck the solder connections, thanks
Check the solder conections by the main voltage transformer that was my problem on two of them
Posted on Apr 09, 2009
  • 2,336 Answers
The only suggestion i have is that you could have a defective flyback transformer if still not turning ON.
You should check B+ voltage and see if it gets to the horizontal transistor, if it does; chances are that the flyback is defective on this TV.
I looked for an schematic, but no luck find one. Looks like they do not exist.
Posted on May 23, 2008
Dropped tv
first check if there was no short cicuit inside or any wire or parts that have contact and can cause also a grounded and make your fuse always blown...
let me know
Jul 25, 2008 | Sylvania 6615LCT 15 in. EDTV-Ready LCD...
Why it is not starting?
when my car was blowing this fuse the starter needed replacing.
Apr 20, 2014 | 2006 Chrysler Sebring
I NEED DIAGRAM OF CONSTRUCTION FOR REGULATOR P5NK50ZFP
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Cars & Trucks
My tv keeps blowing a fuse when I turn on set.
DO NOT keep feeding it fuses more damage can accur-check rectifiers in power supply-then check regulator-chech H.O.transistor.if you need more help im gonna need a model number to go furthor
Sep 04, 2009 | Televison & Video
No power
If you see a light on the front panel, is not the fuse but something else in the power supply circuit board or could also have damaged the main board due to the poor voltage regulation of these power supplies.
Aug 19, 2008 | Protron PLTV-32 Television
Fuse blows, Disney DTD1363
It look like this is the PN p5nk50zfp.
This site has your part. Data sheet
This part, it might be your voltage regulator not the horizontal output transistor.
Good Luck.
Mar 12, 2008 | Disney DTD1363-CAR 13" TV/DVD
JVC AV-36260 TV Problem TV won't turn on
  • blowing fuse is a short circuit problem in your tv.
  • please do not replace fuse unless you know the reason otherwise it may damage tv.
  • fuse blowing is due to
  • main filter capacitor
  • power output transistor sort or regulator short circuit.
  • good luck
Oct 21, 2007 | JVC AV-36260 TV
Blown 4 amp fuse twice
ok appaloosa! is the fuse blowned again? if blow you have fault unregulated power section, you have defective parts like.. leak degausing or defective diodes or capacitor and or regulator IC. 2nd. defective horizontal output. if not blow the fuse u have fault oscillation!
Sep 14, 2007 | Pioneer SD-P55A3-K 55" Rear Projection...
Nothing works
The fact the set blows up the correct fuse is because it has a short ahead in the circuit,it could be one of the diodes(4) that is shorted,if one of these guys is bad all of them should be replaced with the exact replacement,ahead of them it should be a regulator and he is bad (shorted) it could have taken the diodes and the main fuse.The cause might have been a power surge.If you are familiar with tv service you can check the regulator and the diodes before you put in a new fuse,if you are not too familiar be safe and take the set for an estimate.If you suspect power surge or lighting damage it might not be worth repairing.Let Us know if you need more information.
Oct 26, 2006 | Sharp 25N-M100 25" TV
Disney DTD1363-CAR 13" TV/DVD Logo
140 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
