Computers & Internet Logo
Posted on Sep 23, 2010
My Epson scanner keeps producing 'upside down' or sideways photos. I've been told that the "Image Capture on my Mac might be inactive. How can I help this situation?
Anonymous
Level 1:
  • Contributor 21 Answers
  • Posted on Sep 28, 2010
Anonymous
Contributor
Level 1:
Answers
21
Questions
Helped
5754
Points
34
The most likely reason is that the page orientation is landscape when it needs to be portrait or visa versa. you can also rotate the image. The image capture should be in your applications folder, if its not, get from your install disk. Finally the epson printer/ scanner usually has a driver which you download from epson, this will give you an epson icon (usually in the dock) which you can then open a manage things from there. I would at least check that you have the correct driver for your printer/scanner OX version. [email protected]
We would like to connect our Epson GT-15000 scanner to our new Imac 29inch. Although we do have the scanner connected to a G5, we seem not to have any sfotware for Mac, only the Windows CD. Where can we...
No additional drivers are necessary. Your Epson GT-15000 is listed in "Printer and Scanner software available for download,"http://support.apple.com/kb/HT3669 .
To add your scanner, simply plug it in. If it does not appear in Apple Menu > System Preferences > Print & Scan, you may need to run Software Update (also from the Apple Menu, second item down), and then click the plus ( + ) button in the lower-left of Print & Scan, select your scanner, and then add the printer.
The default scanning application in OS X is Image Capture. After completing the above steps, open Applications > Image Capture and you should see your scanner listed on the left.
I have a Canon Rebel XT. After taking a picture, the viewer shows the shot upside down and when I down load to my computer they come in all upside or sideways. Just started doing this and I've had
The EOS cameras have some sort of sensor built in to tell the camera which way the shot should be orientated on screen and when they are transferred to the computer.
It sounds like the sensor is jammed or broken and sensing (for some reason) that the camera is upside down when the shot is taken.
If you don't want to pay to have it repaired you can use a program to rotate them or turn of the image rotate option in the menu. I believe this ignores the sensor information.
How do i downloAD PHOTOS TO MY IPAD
Hi Chris:
You can use Image Capture application to download Photos from your iPad to your Mac. Connect your iPad to your Mac and open Image Capture. You can find it under Applications or Applications > Utilities folder. Image Capture will allow you to download the Photos.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
My Epson Perfection 1650 Photo scanner keeps producing scans that have a 3-4 inch bright panel vertically down the middle. The image is visible, but the outer thirds are quite darker than the middle...
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
2answers
By using the epson v500 photo I get the following massage: "Please remove the document mat and/or close the document cover" Off course I remove the mat and de document cover is close. I send the scanner to...
Possible driver issue. You have to reload the twain driver.
To uninstall the twain driver, please follow the ff instructions:
- Trash epson scan and epson scanner monitor from the harddrive
- Go to the library, then application support. Trash epson scanner module.
- Go to the library again, then image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
Empty the trash and restart your mac.
When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
EPSON STYLUS CX4800
You need to download a "Twain Driver and Epson Scan Utility" from
the Epson Website.
But before you start downloading the Twain Driver we need to delete
the previously installed driver in your computer.
1.) Click and open the MAC or Apple Hard drive / Application and trash Epson Scan and Epson Scanner Monitor ( drag it to your trash )
2.) MAC hard drive / Library / Image Capture / Twain Data Source., we need to trash ( *.ds file )
3.) MAC hard drive / Library / Application Support., trash the Epson Scanner Module
4.) Disconnect the connection ( USB ) between the printer and your MAC.
5. ) Empty your Trash bin and restart your MAC
After the restart we can now download and install the Twain driver to your MAC.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58606&prodoid=56291067&infoType=Downloads&platform=Macintosh
After the installation try to launch Epson Scan under Application
2helpful
2answers
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
1helpful
Epson 3490 does not find the slide I put in the correctly positioned provided frame
3helpful
2answers
35mm Color Slides
Here they are for Mac and PC
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
Epson 2580 scanner
The only thing I can think of is to turn you to be scanned image up side down in the scanner bed.. IE Rotate 180' As another work arround simply open up Paint etc,and rotate the image 180' and save, ya should be all good.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
