1. Power off machine. 2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle. 3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal. 4. Reassemble KCup cradle and reinsert it back into coffee maker. 5. Power on machine. 6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
I had tried everything, but the paperclip, cleaning the K-cup cradle; wiping around the needle; but since the water always flowed without the K-cup; I really didn't think this would work, but I just brewed me a cup of tea; the first drink in 4 days! Thank you!!!! Funny thing, it was such an easy fix.
Thrilled tobe of help.
Isn't a great when there is a simple fix. The sad thing is there is another fix to these same symptoms where this person has stated "it is definitely broken and I can sell you the replacement parts"... Hopefully few people are fooled into paying someone to repair or replace anything when it can be cleaned at the cost of a paper clip... a few cents!
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
-llllllllllll
