Question about Lexmark X4270 All-In-One InkJet Printer
Paper is feeding unevenly on black & white prints
So the type appears smeared and wavering in spots. Strangely if we print color it does not do this. JR from CRC
    Genius:
  • 2,035 Answers
If the paper is lodged too far into the printer and can't be removed:
  1. Press the power button to turn the printer off.
  2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
  3. Close the front cover.
  4. Press the power button to turn the printer back on.
  5. Resend your document to print.
Ensure that:
  • The paper is a recommended paper for inkjet printers.
  • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
  • The printer is on a flat, level surface.
  • The left paper guide is against the side of the paper.
  • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
  • The left paper guide does not cause the paper to bend in the sheet feeder.
  • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
  • Envelopes or the appropriate specialty papers are selected in the printer driver.
  • You are using a paper or envelope size supported by your printer.
Important: Your application may not be designed to print envelopes. For help, consult the documentation that accompanied your application.
Posted on May 22, 2008
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
Since i install a new drum, i have smudges on my copies how do i fix
    Sir/Madam
    If you have Brother Printer print quality problems, Then I suggest You clean the Your Brother printer drum unit as follows:
    Small Spots on the printed pages:
    If your printed document has any small white or colored spots, follow the steps below.
    1.Open the manual feed slot cover.
    2. Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
    3.Using both hands, put one blank sheet of paper in the manual feed slot until the front edge of the paper touches the paper feed roller. Wait until the machine automatically feeds the paper. When you feel the machine pull in the paper, let go.
    Note
    • Make sure that the paper is straight and in the correct position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
    • Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
    • Do not put paper in the manual feed slot before the printer is in the Ready state. An error may occur and the printer will stop printing.
    4.Make sure that the printer is in the Ready state. Press + or - to choose "Color Correction". Press OK.
    5.Press + or - to choose "Drum Cleaning".
    6.Press Go. The printer will pull in the piece of paper and start cleaning the drum unit.
    7.When the printer has finished cleaning, "Completed" appears on the LCD.
    Press Cancel so that the printer returns to the Ready state.
    8.Repeat steps 3 to 7 two more times using a new blank sheet of paper each time. Upon completion, please discard the used paper. If the print problem still remains, please go to the Step 9.
    Large spots on the printed pages:
    Hint If your printed page has colored spots at 94mm (3.7 in) intervals, please follow the step below.
    1. 9.Turn off the printer power switch.
    10. Fully open the top cover by lifting up on the handle (1).
    11. See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Take out the drum unit and toner cartridge assembly of the color causing the problem.
    Caution
    • We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
    • To prevent damage to the printer from static electricity, DO NOT touch the electrodes shown in the illustration.
    12.Push down the green-labeled lock lever (1) and take the toner cartridge out of the drum unit.
    Caution
    1. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
13.Put the print sample in front of the drum unit, and find the exact position of the poor print.
14.Turn the drum unit gear by hand while looking at the surface of the OPC drum (1).
15.When you have found the mark on the drum that matches the print sample, wipe the surface of the OPC drum with a dry cotton swab until the dust or glue on the surface comes off.
DO NOT clean the surface of the photosensitive drum with a sharp object.
Note Make sure that you put in the toner cartridge properly or it may separate from the drum unit.
17.Slide each drum unit and toner cartridge assembly into the printer. Make sure that you match the toner cartridge color to the same color label on the printer.
C- Cyan, M- magenta, Y- Yellow, K- Black
18.Close the top cover of the printer.
19.Turn the printer power switch back on.
If your question was not answered, please check...
Clean the drum unit Brother
Or
If You still need Brother Printer Help I suggest You follow Us On for :
Brother Printer Support
Nov 07, 2012 | Brother Dr420 Black Drum Unit Cartridge
Printer full of ink, but will pring pages either blank of with smeared ink.
Follow these steps to check the print settings for your print job.
  1. In the software program you are trying to print from, click File and then click Print . The Print dialog box opens.
  2. Select your product, and then click Properties . The printer Properties dialog box opens.
  3. Click the Printing shortcuts tab.
  4. Under Printing shortcuts , click the type of job you are trying to print.
  5. Review the following options, and then make any necessary changes.
    • Paper size : Make sure that the selected option matches your paper size.
    • Paper type : If one of the options matches your paper type exactly, select that option.
    • Print quality : If you are not satisfied with your printed page quality, or want more densely printed prints, increase the print quality. To print more quickly, or for lighter prints, decrease the print quality.
  6. Click the Features tab.
  7. Check the Print in Grayscale setting
    • If you are trying to print in color, select Color Options , and then make sure that Print in Grayscale is not selected.
    • If you are printing a black and white image, select Print in Grayscale to fix streaking in black areas.
  8. Click OK , and then click OK again to start the print job.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center , then click Settings , then Printer Toolbox .
Select the Services tab.
Click Print PQ (print quality) Diagnostic Page .
Select the Services tab, then click A- Click Align Printheads or
B- Click Clean Printheads .
C- Click Calibrate Linefeed .
If, after repeated printhead cleaning, the Print Quality Diagnostic page shows white lines across the color blocks in Test Pattern 2 (but no white lines in the gray blocks in Test Pattern 3), one or both of the printheads will have to be replaced. The Print Quality Diagnostic page shows which printhead should be replaced.
Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English)
Nov 16, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
How to set my printer to print black ink only
Option 1 - when printing, go to printer settings and select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black. The pigment black ink will only be used when printing on plain paper. Check the box for 'Grayscale Printing'. If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
I tried this once myself, but the result seemed to be useless for printing photographs.
Option 2 - Using quadtone inks may be the solution. http://www.completedigitalphotography.com/?p=32
Jun 14, 2010 | Canon PIXMA MP540 All-In-One InkJet...
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
How do you specify B&W printing on HP C4400
click "print" then go to the drag down menu that says "preview." go to "paper type/quality" and make sure it says "plain paper." then choose color: "grayscale." then click the "color options" tab and choose "black print cartridge only." if it is on the default paper setting of premium photo paper, it won't let you choose the black-only option. i don't know how to make the normal paper the default though because it won't save this on mine. so you have to go through these steps every time. unless anyone else knows??
Feb 09, 2009 | Office Equipment & Supplies
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Gestetner DSc332 streaks and smears when printing in color
Check to see if you have a paper jammed near the drum near the color ink cartridge interface.
Nov 28, 2007 | Gestetner DSc332 Copier
Lexmark X4270 All-In-One InkJet Printer Logo
98 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
