Question about Trendware TEW-450APB (TEW450APB) 802.11b/g Wireless Access Point
I don't know the IP
Hi!I have a TEW-450APB.While i was making the configuration of AP accidentally i changed the ip of AP to :obtain a IP automatically. Now i can't access the AP because i don't know the IP.the first one was 192.168.1.100.PLS help!
Take a ball point pen and push it into the reset hole on the back of the router and hold it there for 15 seconds and then release. type 192.168.1.1 in your browser and you should be able to log in to it again.
Posted on Jun 25, 2008
    Genius:
  • 1,224 Answers
192.168.0.1<<< type this in your internet browser search bar
default user name= admin
default password= password
this should be what your ip standard would be for router if you dont have a router the ip will be of a serviced number by your service provider
but heres the easy way remove the network connection and software and reinstall this will give you back your ip properly because the comp will find in its plug and play format
Posted on May 21, 2008
This AP is in network x.x.102.0, which has it's own DHCP server. Only lan-port and WLAN are used on AP. I need this AP not to have it's own ip-adress, but devices, that connect to it,using WLAN,...
Ideally, there shouldn't be any configuration needed. Access points are transparent and only work as a bridge between wireless and wired network so devices should obtain their IP info from your DHCP server not the access point by default.
If you face problems, then there might be a DHCP server in the access point, disable that.
good luck
Othman
May 20, 2011 | Symbol AP-5131
I have dsl modem routeur dhcp enabled with ap wifi ssid = x everything ok ip 192.168.1.1 i have tew 637ap n upgrader wire connected on dsl modem router with static ip 192.168.1.20 ssid = y everythings...
You may be trying to connect through a G or B device to your N router. Verify that there are no serious obstructions or that the pc is not underneath something or enclosed. Metal near the pc can cause the signal to lose strength. Not having a wireless N card or adapter can also cause this.
Also if you are trying to connect through ethernet cable verify that windows is being assigned an automatic ip address, if it is static in windows change it to automatic.
Apr 29, 2011 | Trendnet TEW-638APB 300Mbps Wireless N...
How do i connect my symbol ap-5131 to my computer?
exist 2 ways to do it...
first if you now te ip address and the user and password of admin, conect the ap at the ethernet port of you pc and configure it with a ip in the same range that the ap, put the ip direcction in the web browser.
the second way is conect the ap to the serial port and run the hyperterminal if you have windows, maybe you need configure the values of the conecctions.
Sep 15, 2009 | Symbol AP-5131
Cant get accesss to the configuration window
In order to get to the AP, and assuming you just plugged it in, you need to put everything in the 192.168.0.x domain. The AP defaults to 192.168.0.50, so you need to make sure that the router gives out IP addresses that does not include 0.50, or change the IP address of the AP. Likewise, the computer you are trying to log into the AP needs to start in the 192.168.0.x domain, with x being anything but the gateway address (normally 1), or 50.
My guess is you have a router built into the modem and it is giving out different addresses. You can set your network address by hand to be 192.168.0.pick a number like 5 and plug into the ethernet port of the AP (may need a crossover) to get to it.
Post back and let us know what you found.
Carl
May 15, 2009 | D-Link Air DWL 700AP (DWL-700AP) 802.11b...
Connecting Compex 28g to mobile broadband and home network
please check following points:-
1) IP address (some wireless AP's follows ip address such as 192.168.1.1 for AP and 192.168.1.2 for 1st workstation, 192.168.1.3 for 2nd workstation and so on).
2) check connection options in IE. it should be lan setting and detect automatic setting and use automatic configuration script(put IP address of AP)
3) if DHCP is enabled then obtain IP automaticlly
4) check for any WEP security options i AP.
5) user must have internet access rights.
6) if Static IP is Used please give gatway ip (your AP's IP address) and same for DNS IP address.
then restart your system and enjoy internet.
May 01, 2009 | Compex NetPassage 28G Wireless Router...
Wireless computer
Open your web browser and type the IP address of the TEW-450APB in the address bar. The default IP address is 192.168.1.1. At the login, enter your username (admin) and password (admin).
The default IP is 192.168.1.1 and not 192.168.1.100 as you have entered.
Apr 18, 2009 | Zyxel ZyWALL 10 Router
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Mar 19, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Unable to get connected to Belkin f5d6130 AP
You need to be connected using  wired Ethernet (PC's LAN card to Router's Ethernet Port (at the back)).  This is the preferable INITIAL way to configure the router before going wireless. Also it would be to your advantage to initially set your PC (that will be used for configuring the router)  to "Specify an IP address" (static settings) and not "Obtain an IP address automatically."
For a PC connected via UTP networking cable attached to a Belkin F5D6130 AP, the networking settings could be:
IP Address 192.168.2.2
Subnet Mask 255.255.255.0
Default Gateway 19*2.168.2.1
DNS Server 192.168.2.1
Reboot
Post back results. Good luck and kind regards.
Oct 12, 2007 | Belkin (F5D6130) 802.11b Wireless Access...
Linksy
Hi, assuming you are running WinXP, you might want to try: 1) right click on your wireless networking icon and click repair; or 2) double click on the same icon; click on properties, scroll down to/click TCP/IP to highlight, click on properties - Tick Obtain an IP address automatically if your access point is also acting as DHCP server; or 3) get IP add + others from your Network Admin and entered numbers given; or 4) self-assign IP numbers that are pretty near your Access Point (AP) IP #s, maybe something like 192.168.1.3 where your AP is 192.168.1.1, subnet mask should be the same as your AP (normally 255.255.255.0 but may be different) and your default gateway normally would be the IP Add of your AP (192.168.1.1 or whatever the AP is using) DNS could be obtained from your ISP or tick obtain automatically. Caution here that the IP number you select should not be currently in use in your network. 5) Open IE, go to tools/internet option/connection, remove any dial-up if no longer needed and check never dial a connection (assuming you don’t use a modem and would connect normally via wireless. Go to/Click LAN settings, check auto detect settings, make sure Proxy server is uncheck. 6) Ping any website from your command prompt to see if you get a response If all else fail, pls post your AP hardware (brand/model), OS. It might also be a good idea to check if your AP is connected to an ISP with an active account and that your modem is working ok. Please let me know if this works out ok for you. Cheers.
Apr 11, 2007 | Linksys Wireless-G WPC54G 802.11g/b
Trendware TEW-450APB (TEW450APB) 802.11b/g Wireless Access Point Logo
1,241 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
