Question about Toshiba Computers & Internet
I cannot get connected to internet, i have wireless and other laptop is ok
  • 667 Answers
Hi - tracy -don't rate this yet. What's the make and model of your router? Has this laptop ever been connected to the internet? If so - is there a icon on your taskbar for your wireless connection where you can tell the strength of your signal? If there is right click on this icon, and click on available networks. Your network should be listed. Click on that network and click on connect and see if it works. Let know the answers to these questions please. Thanks.
Jeff
Posted on May 21, 2008
Cannot get wireless service
Power on the laptop computer and wait for the operating system to boot.
Right-click the wireless Internet icon in the lower right corner of the desktop.
This brings up a new pull-down menu.
Select "View Available Wireless Networks."
This brings up a selection of different possible Internet connections that are in range of the computer.
Select the wireless Internet connection you want to use.
If a password is required, you need to type it in now.
Wait for the laptop to connect to the Internet.
In a moment the computer is going to state it has successfully connected to the Internet.
click Start, Run type in cmd and click Ok to bring up a command prompt.
Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100.
Check your wireless connection properties under My Network Places.
Right click the wireless connection icon and choose properties.
From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked.
if still no joy
Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok.
For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
hope this helps
Sep 15, 2012 | Computers & Internet
How do i connect my laptop to sony bravia using UWA-BR100 ?
Connect the Laptop and TV with a *CROSSOVER* ethernet cable and then enable "Internet Connection Sharing" on the Laptop's "Wireless Network Connection".
To enable "Internet Connection Sharing", open the Network Connections folder ("Start > Run" type NCPA.CPL and click OK). Right click the Wireless Network Connection, select Properties and then the Advanced tab [XP] or Sharing tab [Vista]. Tick the box "Allow other network users to connect through through this computer's internet connection.
Mar 02, 2011 | Sony UWABR100 Network adapter USB ...
May laptop won't connect to internet, my laptop is in good condition. i already reset my dlink wireless router but still don't connect to internet. The connectivity is ok. my laptop detects the router but...
Is the laptop detecting any wireless networks in the area? if yes then it means that the wireless card is ok if not make sure that the wireless is turned on on your laptop.
I the laptop detects wireless networks in the are then we should check the settings on your system or something that could be interfering with the wireless connection on your system,
what are the error/s when trying to connect wirelessly?
Tis can be multiple things regarding wireless, if the error is windows was unable to conenct to wireless evice then try recreating the wireless network on your laptop in network and sharing center if you have win7 on the laptop, network conenctions if you have XP.
I the laptop connects to the router but does not get internet acces then better check you routers network key if it is correct in your laptops settings, also check your IP address if it is correct if you IP starts with 169... then have a bad IP address on your laptop, go to the command prompt type ipconfig /release, then press enter, then type ipconfig /renew then enter to renew your ip address, hoping that the IP address changes it should begin with 192...
Feb 21, 2011 | D-Link DIR-655 Wireless Router
Just installed Netgear511B. It shows I'm connected
i would go into internet options in explorer and go to connections, then lan settings.verify that auto detect settings is checked, then click ok. restart pc and try ie.
Apr 30, 2010 | NetGear RangeMax NEXT WN511B...
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Wireless connection
Make sure that your computer is getting a valid IP address from the router. If your wireless network is secured, you might as well consider checking the wireless settings.
Oct 06, 2008 | NetGear WGT624 Wireless Router
Laptop won't connect to internet
your internet link is connected but your browser is not configured for wireless.usually once connected,if you restart laptop you can access internet.if this dont help right click on ur wireless icon(in sys tray) and select properties;in property box check wireless connections.
if ur not using a wireless manager put tick in box for let windows manage.press ok or apply.then restart.
Apr 09, 2008 | Acer Aspire 5100 Notebook
Wireless internet connection
Hi Sure you can use Internet wireless first tell me
what kind of internet cannection are you using (Dial up or Broadband) If that is broadband then connect the access point into switch RJ-45 port then put the ip and DNS into laptop which ISP provided definetly internet will run.
if problem comes post it again
good luck
Oct 17, 2007 | Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
