Question about Sharp 25N-M100 25" TV
Sharp Tv 25E-M50
Only have horizontal line, what part do I need to pull up vertical?
I have a 19" sharp tv. after watching for a while, the picture goes out just having a line across the screen. Need help, Great picture when on.modle 19E, M100
Posted on May 24, 2008
    Problem Solver:
  • 7 Answers
WELL FIRST U HAVE TO SEE WHETEHR THE SUPPLY FOR VERTICAL SECTION IS OK.IF ITS OK THAN.CHECK FOR SOME DRY SOLDER AT VERTICAL SECTION.OR ANY LEAKAGE CONDENSER ,AT LAST REAPLACE THE IC VERTICAL.IT WILL BE OK'
Posted on May 22, 2008
I have a sharp tv. the problem is when i turn on the unit it shows a single horizontal line then immediately relays clicks then turns to stand by mode. i already change the vertical ic.
Vertical scan output failure. That is the reason for this horizontal line, right across the center of the screen. Check and replace damaged component/s at it vertical scan output section circuit. Check the solder terminals of the vertical scan output IC; for any loose solder points. Contact any service technician, if you're not handy in electronics.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to TV screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 01, 2014 | Sharp Televison & Video
Screen blanks after 30 to 60 seconds
change 22mf-200v near fly back .
Apr 10, 2010 | Sharp 25K-M100 25" TV
Tv repair
A vertical line means the line is up and down in the middle of the screen. That would indicate that the vertical IC and the surrounding components are working perfectly. A vertical line as described is the result of a lack of horizontal deflection (to move the beam from side to side) Since the high voltage is obviously OK, the problem is most likely a bad solder connection in the horizontal yoke circuit. Examine the bottom of the PC board in the area of the flyback transformer, and yoke connector (has four wires Red, Blue, Green, Yellow).and the pincousion coils, capacitors, etc in between. Flexing the board in that area may cause the problem to come and go. Resulting arcing should also be visible. BE CAREFUL, as hazardous voltages are present in the circuit!
Nov 29, 2009 | Sharp 19R-M100 19" TV
Only a horizontal line can I see in my TV
In most cases the vertical output IC and possibly a fusible resistor off of the high voltage transformer are bad. The vertical output IC is located on a heat sink and usually right next to the vertical yoke winding connectors that are green and yellow in most sets. Please take a moment to rate my answer..Thanks...
Nov 24, 2009 | Sharp 27G-S60 TV
Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Jun 04, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Lines on tv
Hi
this not horizontal this is vertical line. this means defective vertical output IC and 1.5ohms resistor, Replace the two parts then test run, and happy viewing!
Thanks!
Dec 26, 2008 | Sharp 25L-M100 25" TV
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Blue horizontal and vertical lines
We have many problems with loose or poorly seated cables and connectors on these units. Pull the back and reseat all the internal cables, especially the LVDS cable to the LCD control bd. If this does not correct the problem the main cause is a bad LCD control bd. or possible a defective main bd.
Jan 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
Sharp 25N-M100 25" TV Logo
246 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
