Question about Cameras
Memory stick Hi: When I turn on my camera the memory stick symbol keeps flashing and it says 101 next to it and the screen says "no memory space". I've changed the batteries and put in a brand new memory stick. Checked the manual and can't find a solution. Can you help??????
    Champion:
  • 203 Answers
The 101 is the folder number the pics are stored in-what model sony is it?-are you sure the camera is not recording to the internal memory which may be full-did you try to format memory card or reset the camera to factory defaults?-if none of these work may be bad camera-are you using a memory stick pro or pro duo card?
Posted on May 21, 2008
Installed new film memory stick and new charged battery.......... screen flashes format error with several flashing symbols....help.
Hi, best bet, try formatting the memory stick first, then use with camera, format will create a FAT system, should work.
Mar 02, 2015 | Cameras
How do I turn on the flash? I tried to buy a really simple camera and there's just too much 'stuff' on it. everything seems to be ok, just can't figure out how to make the flash work. ...
Easy. When the camera is in normal shooting mode, press the up button (marked with the symbol of a lightning bolt) until the symbol of a crossed out lightning bolt near the top left of the screen turns to an uncrossed lightning bolt symbol. that's it.
extra tips-
  • if you keep pressing the up button until the lightning bolt symbol has a letter A next to it, the camera will fire the flash only when it thinks it is necessary. this will keep your flash from firing in bright light and therefore save battery charge.
  • remember when you flipped through your math textbook in the first grade and it had "too much stuff on it"? you think its too much because you aren't used to it. don't be afraid to mess with the settings in order to learn how to use your camera best; you can never permanently damage a camera in changing its settings. the worst that could ever happen is losing all the photos in memory. if anything else goes wrong, you can always return the settings to what they were when you bought the cam in a few button presses (refer to the manual).
good luck and happy shooting!
Sep 04, 2011 | Vivitar ViviCam 8018 Digital Camera
The camera takes a long time to process the photo
dear sir,
the first solution is to keep some of your phone memory clear,atleast 2 mb.........also keep some 100 mb free space in memory card also...if the card and mobile is fully loaded then the cam is almost dead..........
the next suspect must be your memory card,which has been affected from viruses,while you ve transfered files or received files from untrusted devices,which eventually destroys ur camera also.......
even ater changing memory card,you still face the same problem with a new or formatted memory card,then the problem is caused by virus and sometimes it might be software failure also, which causes some of the menu not tofunction,the only solution is to flash ur camera software from the nearest sevice centre.
thank you.....take care
Oct 09, 2010 | Kodak EasyShare Z1015 IS Digital Camera
When i view the images, it hangs and displays "FILE ERROR". the images are still there and there is no other problem aside from viewing the still images. really dont know what happenned. when i tried to...
dear sir,
Oct 05, 2010 | Cameras
Pictures are already deleted but camera space is still full
Format the memory stick using the camera's "Format" command. You should NEVER use the computer to delete your pictures.
May 08, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Memory sticks empty and shows no memory available
i have a solution that worked! Notice: save all the needed data on your computer, because Formatting your Memory stick will wipe everything out!
if you have a Sony PSP, or know someone who does, replace the memory stick that says "no memory Space" in to the PSP port, go to "Settings" which is the left-most section of the PSP main screen, then scroll down to "System Settings," select it, Scroll down again to the "Format Memory Stick" selection and press "X" follow on-screen instructions and  SHAZAM!  its ready for action in your camera again!
-Indy
Nov 16, 2008 | SanDisk Memory Media
Sony DSC-T2 lost flash feature
take it to the near service station you circuit belt insde is came out due to vibration or must be fall
Jun 07, 2017 | Sony DSC-T2 Digital Camera
No CF card
The camera body has a tiny switch marked "CF" in one position and Sony's "memory stick" symbol in the other. Apparently I accidentally reset the switch from "memory stick" to "CF" while slipping the camera body into (or out of) its carrying-case. Once I had set this switch from "CF" back to the "memory stick" position, everything worked fine. Solution:  read the user's manual more carefully next time!!
May 08, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
Format Error C:13:01 on Sony DSC-W7
Please try with the new memory stick. Regards, Arpi
Mar 26, 2007 | Sony Cyber-Shot DSC-W7 Digital Camera
Cameras Logo
125 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
