Question about Mitsubishi VS-6043 60" Rear Projection Television
No picture or sound,clicking in back and speakers thump to clicking noise
Picture went out then the sound.can unplug connector on side of red tube only and get sound back and clicking stops.also picture will flicker when this is done then it goes completely out again but still has sound and no clicking noise. and no thumping through speakers. any help will be appreciated. thank you
    Problem Solver:
  • 26 Answers
Tubes are messed up, to fix is REALLY expensive, trash it or part out what can still be used.
Posted on May 28, 2008
Sound system makes a thump thump noise
Your speaker is now blown.. Replace the Speaker and you will get sound back instantly. Happened to my Drivers Speaker last week, replaced the speaker and life is good again.
Mar 01, 2014 | 2010 Kia Soul
No picture but the red power button blinks each time it blinks there is a thumping noise from speakers and a clicking sound
try checking the fuse area, together with the capacitor & resistor may one of them is faulty. and also check for any bad soldered.
let me know
Oct 31, 2008 | Haier HTF27R11 27" TV
Polaroid flm-3701 monitor no power
Hi Cliff. the control board (as seen here: http://www.ebay.com.au/itm/like/251052948534?lpid=87 ) May be the only option. But once one thing has gone others may follow, ie Even the screen itself may have been hurt. I would highly suggest to throw it out and just buy another screen. Note, that model does NOT come with any 'fuses' inside, hence probably why it sparks still.
Nov 09, 2013 | Polaroid Televison & Video
Jvc 56 inch television went black, then a large thumping noise, and I tried shutting off the power and could not, so I had to unplug the television; the television now will not come on.
sounds like the WP30 or WP74 series that has a convergence shutdown which will usually cause the thumping through the speakers. Unplug the convergence power board and see if the set will power up. Do not remove the rear cover the board is up front behind the speaker grille. Never remove the rear cover on a JVC rear projection as it can damage the digital circuits due to the safety interlock on various JVC models.
Nov 17, 2011 | JVC Televison & Video
Hi.. I have a bose wave ipod docking system.. the sound is amazing.. or was... until a few weeks back when i noticed that in order to hear my ipod... i had to tweak the ipod a little on the docking...
Are you using a voltage adapter of some kind to convert the ireland standard 220VAC to the USA standard 120VAC that this device uses? Over voltage can deplete an electronics life very quickly.
By the sound of the "thump-thump-thump" noise emitting from the device, you may have a broken ipod dock connector, or a short somewhere in the connector/wiring/device itself, or the ground has failed.
By the description of having to "tweak" your ipod to hear it, it sounds like you've slowly broken the dock connector. Check to see if it moves easily, or if you can hear anything loose.
This is more than likely fixable, but it's probably easier to replace the device than to fix a broken connector.
May 26, 2011 | Bose Battery for SoundDock Portable...
Dead polaroid model 2700 visionquest tv
Your power supply has failed; have it replaced
Jan 16, 2018 | Televison & Video
RCA P61960 projection screen. no picture, no sound. tries but shuts off.
It will depend on the Chassis number you have but it sounds like a bad Deflection module or a bad Convergence power supply module. The Convergence Power supply module is on the left looking from the back mounted above the deflection module. On newer models the picture tubes can short and put these sets into shut down mode ( Three Trys). Start by unplugging the CRT modules off the neck of the tubes one at a time. If it doesn't come on you have eliminated the tubes. There will be a Red and Black set of wires from the deflection module to the convergence power supply module. Unplug it. If it fires up then it's the convergence power supply module. If not it will probably be the deflection module. The flayback transformer is a common problem along with several bad caps towards the front of the board. Let me know if this fixes it.
Oct 02, 2008 | RCA P61960 61" Rear Projection Television
No responce except thumping noise
PLEASE TRY TO CHANGE AGAIN THE CONVERGANCE IC'S
Oct 02, 2007 | JVC AV-48WP30 48" Rear Projection...
Popping noises and no picture or sound
try replacing the stk's on the deflection board (making sure that all of the resistors on the board are OK and that there are no solder cracks I found one of the jumpers had a bad solder joint on the one I worked on) but if that doesn't fix I have some raw research that might give you somewhere to start :
No. The CRT driver ICs are prone to shorting and cause this symptom (I just had one with those very symptoms and the green CRT driver IC was shorted). Disconnecting the CRT board does not clear the short on the board. Often then is a small burn mark on the CRT board under the affected IC (but not always). The IC should be a TDA6111Q. Be sure to note the proper position
of the IC as it should face with the letters TOWARD the heat sink!!!!
Larry, Check the CRT driver ICs on each of the CRT boards.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxx
Hi Guys, I don`t see many JVC`s and don`t have the print for this AV48WP30, went out this morning and as customer claimed on phone when you plug set in and turn on it makes a loud thump thump in both speakers 20-30 times then relay clicks, the thump stops, and blue idiot light on front goes dim/bright, dim/bright, have to unplug set to start this same scenario over again. Never develops HV or audio, Will order the service manual today, but would like to know if anyone has seen this before (should say "heard" this before)
I would disconnect each crt board and hv lead one at a time and try. Have seen several bad tubes on that model. The only other problem I have seen on that set is bad convergence amps, however that doesn't cause shutdown.
Perry Bower
Electric Medic
From Tech Repair CD:
JVC\AV48WP74\just went click*click*click when turned on Video drive IC (IC1101) on the red CRT module
shorted. It looked like bad solder on the B+ was the cause
Frequently Used Top Five Repair Parts by symptom code
MODEL NUMBER : AV48WP30 - TV
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Above from JVC Web site, also I have seen shorted video drive IC's on the crt boards short and cause this symptom. Try unplugging the 200 volt source to the crt boards and see it the set powers up and stays on. There is a B+ relay which supplies 130 Volts to the horizontal output circuit. Is this relay energizing? I takes about five seconds after the power is turned on for it to energize. If a short is detected on the 130 volt line the blue power lamp on the front will do what you describe and the relay will pulse on and off. (David)
Symptom:
Non-functional Digital Input
Solution:
1. Power off the unit
2. Disconnect the digital input if it is connected
3. Remove the rear cover
4. On the digital input module, using a shorting pin (PC type) or a
jumper, short Pin 1 and Pin 2 of the
SB connector
5. Power on the unit
6. Unplug the unit and remove the shorting pin or the jumper
7. Re-attach the unit’s rear cover
8. Power on the unit, and input the digital source
Jan 16, 2007 | JVC AV-48WP74 48" Rear Projection...
Repetitive dull thumping noise
You're in the UK, right? Try unplugging the set from the mains and let it sit for ten to fifteen minutes. Are your speakers built in or detached? How long has this been happening? Have there been any changes recently that coinside with the problem? Are there any other audio/video devices connected to the set? If you have other devices, does the problem exist when they're in use? The clicking noise sounds like a relay that's searching for another device or input. Check the audio settings on the menu to see if something has changed. Hope this helps.
Nov 19, 2006 | Panasonic TX-28DK2 TV
Televison & Video Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
