Question about Maytag MAH6700AWW Neptune Front-Load Washer
Maytag Neptune MAH4000AWW
Wash machine fills and gets power. It just stops once it fills as the tumbler won't agitate.Purchased in 2000. Serviceman says it needs a new motor $500. Is his diagnosis legitimate?
  • 2 more comments
  • Don Foreman
    Don Foreman May 29, 2008
    No codes were given to me so don't know what they were. After filling drum does not turn, when turning to drain, spin it empties but does not spin,. Service man says it needs a new motor and wants $500 to put in new one. Just trying to confirm his diagnosis with all of this.
  • Don Foreman
    Don Foreman Jun 01, 2008
    Thanks for the manual but a liitle too complicated for my skills.
  • robert samples May 11, 2010
    also after it fills turn it to drain spin and tell me what happens
    has he been there and looked at it and is it showing any codes
    President:
  • 1,314 Answers
Email me at b4829@yahoo.com also it may not be the motor matags had a promblem with a resistor burning out on the control bd on your mail put maytag motor as the topic and will reply
Posted on May 29, 2008
  • robert samples Jun 02, 2008
    well i sent it to you because you can change the motop save some cash i can tell you the motor dont cost 500
The washer will not go into High Spin. I had the problem before, when a penny was lodged in one of the agitators. I need to know, how to remove the 2 agitators in the washing tub, to remove any debrei
You have to pry off the caps on the tumblers. Try not to produce any burs on them so on reinstall they dont snag the wash load.
Once you have the caps off you take a #20 Torx driver and back out the tumbler retaining screw the SM does not call that out.
Page 37 of the FAV6800A/FAV9800A Service Manual will detail this?
Do you have the SM? If not join this forum and download SM 16022808 Maytag Top Load Neptune Washer Service Manual
Oct 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Won't progress beyond wash cycle -- start light is flashing. Cannot switch from "normal" to delicate or any other choice. Maytag Neptune TL FAV6800AW
So I understand the issue. Does the wash cycle start up? By that I mean if you release the washer top from the base do the tumblers turn once the water fill cycle is complete?
If you don't have the FAV6800A/FAV9800A Service Manual (you can't get it on line anymore) see this post Clutch Fix I describe how to release the washer top from the base to observe the wash basket. Don't raise during the water fill cycle wait till that completes.
Does the key pad beep as you press the other cycle select key pads?
This could be a Control Board issue...........Rich
Oct 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag FAV6800AW have replaced clutch and cleaned under tumblers. Machine will not balance. When rotating tumblers entrie drum rotates (during cycle). I removed drum and no leakage out bottom. Does this...
Let?s see if I understand. Are you in a wash/agitate cycle when this happens? If so is the wash basket rotating Clock Wise with the tumblers rotating (washer top raised for observation)? With A Spin Only cycle selected and some clothes in the wash basket. Raise the washer top from the base and observe the wash basket rotation. The wash basket will rotate CCW the spin direction. Do the tumblers rotate while the wash basket is rotating CCW? If so the load will go off balance. What series is your machine it will be the first two digits of your Serial Number i.e. 10 through 17. Was the original clutch replaced because of severe rust of the One-Way Roller clutches/bearing in the clutch Pulley assembly? Do you have the original clutch pulley assembly? Did your machine use the upper the One-Way Roller clutches/bearing ring? Your series number will help me but if you can confirm. I?ll try to help?.Rich
Jan 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune washer
Why?Do you understand that the bearings are locked into the outer tub and you have to replace that,the outer tub.Very expensive repair that will most likely be almost half the price you had paid for the machine new.My advise is DONT FIX this if you have a bearing problem ,because I honestly believe in letting the customer know the truth.Sorry, but a 15 year old re- conditioned Maytag will out last any Neptune ever made.
Apr 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
I SAY REPLACE TIMER (POWER CONTROL BOARD)
Jan 15, 2008 | Maytag MAH6500 Neptune Front Loading...
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag MAH6700AWW Neptune Front-Load Washer Logo
199 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
