Question about Whirlpool Dryers
No heat I have a older model GE dryer and the heat doesnt come on. I hear a clicking sound like a timer by the knob while the dryer is off. The dryer spins but its only circulating air, no heat. Please help, what might be the problem and how much could it cost to fix?
It happens to me too in a different dryer when it goes off it does click click click click fast
Posted on Jun 25, 2008
  • brenda gordon Jan 28, 2012
    Sorry to hear that was happening to you too ...**** why is that listed as a solution??? I need help not company.
GE dryer model DCA3BC8776 'Start' knob has come
you should be able to replace the knob from the front of the panel without removing the control panelit has a "D" shaft on the knob and shaft also has a "D" configuration too? right?
Aug 18, 2011 | Major Ge Dryer Timer Knob We1x1263
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
Hello, My GE Dryer, Model M460-G timer won't shut off
Sounds like you have a faulty timer switch, check with your local supply house and get the same type of switch.
When you go to replace the timer switch, unplug the dryer, then remove one wire at a time. This will prevent wiring mix-ups.
Good luck,
I hope this helps
Oct 11, 2009 | GE Dryers
GE Dryer model DCL333EAOWW that will not start
I have a GE (Model #: DCL333EAOWW) Dryer that will not heat up properly and the timer does not work
Aug 14, 2009 | GE Dryers
GE Dryer timer doesn't work
Replace the timer . If model number given , could give the part number .
Aug 09, 2009 | Kenmore 800 6983 Electric Dryer
No heat and will just keep running
lets see hear,..when your dryer starts do you hear two clicks or one.the first click is the motor centrifugal switch the second is power going to the gas valve and energizing the coil.if only one click.you need to check the fuse in the back of the dryer .its white ,i call it a missile and it has two wires too it .you can put those wires together and isolate with tape and if problem unit will run.if that was the problem you need to make sure all venting is clean also inner dryer air channels,but it sounds like you checked those.if two clicks your ignitor may have failed.you check that with a volt meter 110 volts i hope that gives you somthing to run with . God bless ,tom
Jan 23, 2009 | Dryers
GE Dryer timer stoped working and so it runs and runs
Dryer knob assembly unit is faulty and loss of heat sounds like an element going out.
Dec 10, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
67 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
