Question about Zebra TLP 2844-Z Thermal Label Printer
How come a thermal printer needs a "ribbon"?
After owning a TPL2844 printer, for a month I still have no joy determining the "ribbon" needed to print on the 4x6 labels.  No even the "customer service" folk at Zebra seem to know.  Might this be "typical" service for this company?  The unit is shipped from Zebra with virtually no information or supplies.  Enquires made to "customer service" made by both the purchaser and the seller have not been able to come up with any answers.
At this moment the printer works with ribbon #800130-103 that is 3.31 inches wide where we URGENTLY need a ribbon that is 4" wide.
Does not seem to be rocket science but we just cannot get any answers from anyone.
Anyone know the answer?
"Mystified"
  • 300 Answers
You can get 110mm wide ribbons see link below -
http://www.zebrasupplies.co.uk/?gclid=CIydzeGduJMCFROA1QodFk-oCQ
Posted on May 21, 2008
When i try print the label..no output at the label..how to test whether the ink is function or not
I'm including this link to the users manual:
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
But here is the basic troubleshooting info for that issue
No print on the label.The media may not be direct thermal media when printing without ribbon (i.e. thermal
transfer). See the test procedure
Determining Thermal Media Types on page 29.
• For thermal transfer printers, the media may not be outside wound or approved for use in
the G-Series printer. See the following ribbon test procedures: Ribbon Test with Adhesive
on page 32
and Ribbon Scratch Test on page 33.
• Is the media loaded correctly? Follow the instructions for
Loading Roll Media on page 11
in the Getting Started section. For printing using transfer ribbon, see
Loading Transfer Ribbon
on page 14.
Mar 28, 2011 | Zebra GK420t thermal transfer and thermal...
Tip
Can my thermal transfer (TT) printer print on any label?
The answer is no. The labels must be specifically coated with a thermal transfer overprint. Most flexo printed labels have a UV varnish to protect them, that does not print very well in a thermal transfer printer. You must let your label printer know before the labels are made that you need a thermal transfer overprint and no UV coating.
Also, see my tip "How to determine the formula of ribbon you need"
on Aug 20, 2010 | Office Equipment & Supplies
Tip
Not all thermal transfer ribbon formulas print on all materials, the key is to match the label material with the proper ribbon. There are three main types of ribbon formulations used in most thermal printers.
Wax -
  • the least expensive
  • works best on thermal transfer paper labels (it may print on the other materials to some degree but will easily scratch off)
  • looks the darkest (more opaque) when unrolled and held in front of a light
Wax / Resin
  • this is a very wide ranging category, some formulas are the same price as wax, others can be almost the same price as resin
  • works best on thermal transfer labels paper, preprinted thermal transfer labels, and many polypropylene materials
Resin
  • the most expensive
  • the most durable
  • is UL approved when matched with a compatible material
  • works best on polyester and polyolefin
  • looks the lightest (more translucent) when unrolled and held in front of a light
I have a few Datamax-I-4206 printers and some of them have the Thermal Transfer ribbons and some do not....Do I need to have Thermal Transfers or cant I just print to them without it?
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
Dec 31, 2010 | Datamax DMX I-4206 Printer
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
I cant seem to get rid of the "Ribbon In" error on my zebra S4M
1st change the print method to direct thermal on the LCD panel,  then check the driver on your computer, make sure you are printing with direct thermal
u can check the driver at printer & faxes , right click the printer and select printing preference .
Feb 11, 2010 | Zebra Z4M Printer
Zebra 105sl printer shows Error Code: ribbon out Printer Idle: 60-16-3z after we moved it from a different location. However, we've been printing fine w/o ribbon for many years.
so u used the direct thermal label that doesn't need a ribbon ? check the driver at Printer & Faxes on the PC, change the print method on the printing preference from thermal transfer to direct thermal
Jul 21, 2009 | Zebra Printer 140-751-00000
110xi111plus error code: warning ribbon in? what does that mean?
that ribbon occures when you are set for thermal direct printing in the driver or printer and you should be set for thermal transfer in the driver in printing defaults off of the advanced tab and the printer needs to be set for thermal transfer in print method in the setup menu. thermal transfer is printing with black ink ribbon and paper and thermal direct is just chemicaly treated paper.
Jul 02, 2009 | Zebra Printer 140-751-00000
How to reset factory default S4M. I try Pause and feed at starting the printer but it does'nt works. I have a display message: ALERT RIBON OUT.
This may be related to the printing mode you have configured. If you're printing on a thermal paper (direct) and the printer is configured for thermal transfer the printer will notify you that you are out of ribbon.
If you are printing on a regular paper and using a ribbon (thermal transfer) and the printer is configured for direct printing, the printer will notify you that you have a ribbon when you don't need one.
I hope this helps.
Regards,
Fábio
Jan 13, 2009 | Zebra S4M Thermal Label Printer
No print with ribbon
Did you put a ribbon in your printer? The zebra does both direct thermal and thermal transfer, but you need a ribbon to get it to print AND have to change the settings to let the printer know that it needs to use the ribbon instead of direct thermal.
Jan 08, 2009 | Zebra Z4M Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
107 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
