Question about Acer Computers & Internet
I have a vista machine and have a remove hardware safley icon on task bar only the hardware is my sata hard drive any ideas
  • solar0nights May 22, 2008
    IM NOT A COMPLETE GIMP IT WOULD BE OK IF THE DRIVE WAS USB BUT ITS MY INTERNAL HARD DRIVE ON MY LAPTOP
    Problem Solver:
  • 5 Answers
That green icon is for the sata hardrive that you connected
since it is plugged in via usb cable your computer detects it as a usb device which is normal and theres no need to be alarmed.
Posted on May 21, 2008
My Computer not showing my toshiba canvio hard drive
Have you tried shutting down the computer ... unplugging the hard drive ... re-starting the computer .... and plugging in the hard drive (after the system is all ready for use) ?
It's likely the hard drive was "ejected" ... (after defrag ? or when the system went into standby/hibernation) .... and hence you see the icon in the task bar ... indicating that you can safely unplug the hard drive from the computer.
Feb 18, 2014 | Toshiba Canvio 500 GB USB 20 Portable...
Tip
Same problem here.........clicks n all...... After smacking the external hard...
My hard drive was dead and wasn't recognized by the computer, it didn't even start, just a few clicking noises, which according to some of the experiences is the same as a DEAD Hardisk. Anyways, as I read that sometimes this happens as a result of a hit, well, I wacked my HD as a last hope for it to recover its "memory" (as in the movies) and believe me or not, it worked! I don't know if this might help yours, but it saved mine!
The way I did it was like this: I started the pc and when the HD started to run and I heard a couple of clicks, I hit it against the table while in vertical position (assuming that the arm of the HD might slightly move better that way) one time, and then when the spinning and the first click was heard agin I hit again. After that I heard the typical searching sound of a HD, and you can imagine I started to pray that what I heard wasn't my anxiety sound (if it has any). Now I am a firm believer in the old trick of whacking the old TV to get the vital signal back!
Good luck to you too!
on May 29, 2009 | Western Digital 250GB MyBook External USB...
0 bytes
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy. You need to format the flash or external drive. Format thedrive as primary drive and in FAT32. (FAT32 will allow data to be exchangedbetween MACs and PCs also between XP/Vista and earlier versions of Windows).
Apr 13, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I purchase a kingston 32 GB pen drive but it nt work
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove Hardware icon and then click on USB flash drive you want to remove)
Dec 07, 2009 | Kingston Technologies 512MB DataTraveler I...
Just need step by step instructions for downloading to my pc using a 8gb thumb drive to a vista pc
Thsi type of thumb drive should automatically install, in other words your computer should recognize it and it should place an icon on your task bar. Click on the icon and open the drive. Or click on your start bar, double click on my computer and open it from there, depending on your pc, it should be either e-j, never c
Sep 30, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
After a power failure I pushed the power button on my WD Dual-option external USB 2.0 hard drive as I normally would do to turn it back on. But I also noticed that the Unplug or Eject Hardware icon on my...
First of all it is not that necessary to click the Unplug Eject Icon for removing the Hard Disk. Default with Windows XP Opearating System there is a option for removing the USB External Devices without clicking the Unplug Icon. So no need to worry.
Sep 14, 2009 | Computers & Internet
Task bar displays
Just right click the task bar and click properties and then click customize , then click restore default Over!!!!
Aug 22, 2009 | Microsoft Windows XP Professional SP2 Full...
Device cannot work
Try cleaning your computer for spyware and viruses. Also try cleaning your registry out using a utility. Do your USB ports on the computer work with any other devices? Try using different USB ports and make sure theres no faults in you device list with the USB drivers. Let me know more info. What OS are you using. By unplugging it without safely removing is most dangerous to Flash memory but it's definitely possible to damage a hard drive by doing so. You might have corrupted your drive. Hope this helps.
Jul 25, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Correct way to remove drive from notebook with vista
When removing the prn drive from any system go to task bar select the pendrive icon select the option " Remove the drive safely " after that pen drive light is off then it will remove it
Are do this way
Go to Mycomputer select the pendrive icon right click select the option is " Remove safely the drive " then pend drive light off then it remove
Jun 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Ipod shuffle (2nd generation)
alright, when you plug your ipod in you will see on the bottom right of your screen (the task bar) that there is a wierd looking symbol right click it and click safley remove. if you dont see this symbol symply click start or look on your desktop for the "my computer" button open it and it should show your ne of your drives saying ipod something right click it and click safley remove
Jan 30, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Computers & Internet Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
