Question about SanDisk Sansa e260 MP3 Player
Sansa E 260
Suggested solution was to go to the mp3 player settings> USB and change the "mode" This option is not there. Did it get deleted? How can I get it bACK?
  • 8,596 Answers
I don't know your original question, so i cannot give you a direct answer.
The native menu for this player does NOT contain such an option. Go to the following website or www.sandisk.com to get the manual for your player- i have generally found it to be one of the best Mp3 Player manuals around:
https://www.customernation.com/pls/ps/ps.ps_main?p_host=304&p_supplier=5096&p_parm=PSHPP
Posted on May 23, 2008
I hv sansa clip 1gb - in which i have some songs i.e aprox.850mb and that cannot be seen in my pc in sansa clip as a drive g.how to delete songs and add songs , is there any driver of software or...
1. First, check your device setting up on MTP or MSC? Turn on device, go to "settings" , press down or up to find "USB Mode", you can see the check mark at MTP (auto detect) or MSC mode. Change to another usb mode.
2. You have 2 ways to delete songs:
2.1. Delete songs by device: play songs, press down (sub menu) until you meet "delete song", select it and yes
If you delete all items in device: Settings, Format, and yes
2.2. Delete songs by computer: plug device to computer, double click on device icon, Music folder, and delete songs you want. If you don't see songs in there, unplug the device from pc, and then change USB mode, and plug device to pc to delete.
Good luck
Feb 01, 2010 | SanDisk Sansa Clip MP3 Player
Delete songs from mp3
1) Go to Settings/USB Mode and change to MSC mode which make it works as a flash drive/memory stick 2) In Windows explorer, you should see two drives in My Computer, one for the unit, one for the card slo 3) As for a 'normal' PC, you can now just delete any files/songs from your Sansa directories in either drives! (you can also move existing or add new files). note: if your normally use SanDisk Media Converter program or Windows Media Player, you must change the USB mode setting on your Sansa back to 'MTP' before those programs can see your device.
Dec 20, 2009 | SanDisk Sansa e260 MP3 Player
I have a sansa fuse and a jvc home theater. when i plug the sansa into the jvc's usb port all i get is ''reading'' on the jvc display screen and connected on the sansa screen. Do i need a memory card?
Your Fuze MAY have an option to change USB modes If it has this option, go into the "Settings" menu and under "USB" change the mode the Fuze uses to communicate and see if that helps.
Keep in mind, changing it will affect how it connects to the computer too, so you may have to change the setting each time you switch between the computer and the home theater, unless you find a mode that works for both.
May 03, 2009 | SanDisk Sansa Fuse MP3 Player
How do I UNDELETE a voice recording I deleted on my sansa e250?
sorry. but i'm pretty sure you can't undelete something. Be careful about what you delete next time
Feb 26, 2009 | SanDisk Sansa e250 MP3 Player
How do I delete songs from my player ?
Did you try changing the usb mode?
settings/usb mode (down at the bottom)
Try changing this to MSC mode.
I hope that helps.
Aug 02, 2008 | SanDisk Sansa e260 MP3 Player
Unable to install software for sansa e 260 R mp3 player
Go to settings on your sansa and scroll down to USB Mode.
Change it to MSC.
Apr 11, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 is not recognized by by computer
**** this sansa e260 the piece of **** froze on me twice and both times i took it back to circuit city and just got a new one. one suggestion when you do get this is keep the repeipt for it
Mar 31, 2008 | SanDisk Sansa e200 MP3 Player
Deleting music from sandisk sansa E260 4FB mp3 player
you can change the usb mode in the sansa player settings to MCS then connect it to the computer, in windos xp the device will be recognized automacally. go to the explorer or to my pc and you should see it there.. go to the folder music and delete what you want,, you can copy music as well.
then desconect it safely and restart the device,, It will refresh the database and that's it.
you can change the USB mode bac to MTP if you wish.
Feb 04, 2008 | SanDisk Sansa e260 MP3 Player
Stuck Screen
It seems as thought the player itself has actually frozen. I have the same player and it has never done this to me. If you havent allready try leaving it alone in a quiet place for a day or two until it runs out of battery. Then plug it in to your PC to charge and it should be okay. As this has happend to me with other players. If it isnt however, try to resolve the issue by somehow updating the firmware. Try googling "SanDisk Sansa e260 Firmware Upgrade" and see what you can find. If there is something which looks hopeful try it, but if it doesnt work, the perhaps the only option is to return or exchange the player at its place of purchase. P.S Check the USB modes.
Dec 31, 2007 | SanDisk Sansa e260 MP3 Player
Not working
change the usb type to MSC under settings. when you connect the player to the computer it will now show up us a harddrive. right click on the players icon and select format IT WILL DELETE EVERYTHING ON THE PLAYER. after that has been done it should work properly just sync all of your music back onto it.
Dec 24, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
