Question about Ricoh Office Equipment & Supplies
I have a Ricoh AFICIO 220 displaying error message SC544 "Toolbar - Wrench - Functional Problem. Can you please tell me what the error code means & how to fix it please? Thanks! Warren C. Kosel 585-247-3420 Alphabet Campus Child Care Inc. Rochester, NY 14606
I have a aficio 270 copier. a error code 750 is on display.kindly tell us about this code and solution
Posted on Jul 14, 2008
  • 162 Answers
• Fusing thermistor defective
• Poor connection of the fusing unit
Inspect the parts mentioned later:
Enter SP 5-810 (SC code reset) and select “1”. Then hold
down the Photo mode key and the ! key at the same time for
at least 3 seconds (this does not require the main switch to
be turned off and on).
If the problem persists:
• Power supply board defective. Can have defective soldered.
Posted on Sep 02, 2009
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Error code SC 544
Relates to fuser unit. Needs to be reset from service mode.
Mar 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Nov 30, 2007 | Office Equipment & Supplies
710 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
