Question about InFocus LP 600 Multimedia Projector
LP 600 display is green
I thought the lamp was going bad and replaced it, but the color is still way off.
  • Anonymous Jul 14, 2008
    The display projects blue.
  • 563 Answers
Hi WrenOrlando
Could you please describe the off colour to me in detail.
Also try to check if it makes any difference using another cable ?
I'll be awaiting your reply.
Posted on May 22, 2008
Hitachi 50c20 replaced lamp color is green
Go to menu then color ,Tint adjust the tint if that does not clear picture then you have Bad Lighht Engine Encompass parts Distribution might have it go to their website and type in your model number 1-800-638-3328
I always look for Parts on Ebay find better deals their sometimes.
UED might have it also 1-800-648-6657
Jul 16, 2010 | Hitachi Televison & Video
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
Green bulb-or lamp on ultravision hitachi 57uwx20b does not work how much to replace?
On a projection television you will have to replace all three(red,blue,green) projection guns in a matched set, the reason is if you replace just the green gun, your picture will be over saturated with green light making your picture look green,because the new gun will be alot brighter than the red and blue guns.
With that said, repair will cost approx.$400+, I've heard up to$600. Good luck !
Jan 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
After display goes black monitor green power light remains ON. Power can be turned of and the display again stays on approximately 5 seconds. Replacing capacitors in power supply did not correct the...
The problem can be the lamps are bad, the only way to tell is to remove the lamps, look for poor soldering works where the wires are attached to the lamps, bad lamps will have very dark color at the end of the lamps, just like bad fluorescent lamp you see when it is worn out, anoher sign of bad lamp is pinkish glow when lamp si first turn on. The transistors and caps are good in the inverter section?
Jan 02, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
LP600 - Lamp Did Not Strike
Check for shorted flat pack diode in power supply.
Feb 04, 2009 | InFocus LP 600 Multimedia Projector
LP600 - Grainy picture, very poor quality
Single chip DLP projectors use a spinning color wheel between the lamp and the DMD (mirror chip) to produce colors. If the wheel rotation/synchronization is disturbed, colors will not be displayed correctly.
In my case it looks like the wheel became un-synchronized, probably because the projector was dusty/dirty inside (a light senor is used to detect the wheel position), resulting in a grainy, slightly flickering image.
I simply blew out the components with a can of 'Dust-off' and, using a small tool, rotated the color wheel by hand to make sue it wasn't rubbing or jammed.
I reassembled & started the projector and the image was back to normal.
Jul 19, 2008 | InFocus LP 600 Multimedia Projector
Infocus LP 600 will not power up! It is not the cord or the outlet. Thanks Paul K
Hi Paul
Does the counter on the LCD display ontop of the Projector work ?
If it doesn't your Powersupply board will need replacement.
If the counter does work , it is either your lamp or the Ballastboard ( lamp's powersupply) that is faulty.
Mar 18, 2008 | InFocus LP 600 Multimedia Projector
Infocus 540 lamp didnt strike keep trying
if mains is ok and fan running ok, could be a bulb service issue, all lcd projectors have an internal lamp life counter which counts down and once the lamp has reached the end of its life it will not fire up and a new bulb will be required.
Dec 01, 2007 | InFocus LP 600 Multimedia Projector
Please help
I believe that does mean the lamp is dead. If your model is the LP600, you need the SP-LAMP-019. A quick search on eBay found one for $320 new. From the InFocus website it is $499 so that is not a bad deal. InFocus offers a 6 month warranty, so that is something you will want to keep in mind.
Sep 16, 2007 | InFocus LP 600 Multimedia Projector
InFocus LP 600 Multimedia Projector Logo
85 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
