Question about Palm Treo 650 Handheld
Palm 650 stuck in loop
My Palm 650 is stuck in a loop turning off and then back on again going through the startup bar with the palm one logo. I have tried all of the recommended restarts that I can find on the web including the one that you hook the phone into a hotsync cable. Any help would be appreciated
  • sudhir sinha May 25, 2008
    my new palm treo 650 gets stuck in loop.after intialisation,the screen gets blank.i tried all methods including hard reset,but does not work.kindly suggest.
    Champion:
  • 230 Answers
You have to hard reset it. Remove any software that you just install.
Posted on May 21, 2008
  • Dung Nguyen Jun 02, 2008
    scsinha, take it back for software reload since it new and you don't have much information on it.
    FD258, can you hotsynch it and remove the installed software that is causing the problem ?
Is there a way I can revert my Palm Treo 650 back to original factory settings
Factory Reset for Treo 700p and 680 smartphones
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Mar 11, 2010 | Palm Treo 650 Handheld
Palm lifedrive wont' boot stuck on palm screen
This sounds like the issue where the LifeDrive is stuck in a loop. You can see how to break the device out of the system loop on the Palm Knowledge Base article (26419) located HERE.
Hope that helps get you up and running again!
Sep 12, 2009 | Palm LifeDrive Mobile Manager Handheld
Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
How do you do a hard reset on a treo 650
1. Backup your data first.
2. While holding the red hang-up key, click the reset button. Keep holding the red key until after the progress bar completes and the Palm logo shows.
3. You are then asked if you are really sure - Pressing the up key at this point completes the hard reset.
Dec 18, 2008 | Palm Treo 650 Handheld
Palm Tx problem after hotsync
I had the same issue, the palm is stuck in a loop,
I got mine out of this by pressing the power button while the palm was on the screen where the bar goes across the bottom, it asked me if I wanted to erase all data, I said yes, and it reboot normally, I went thru the setup, and all is o.k.
I did have to try this several times, but it eventually worked. Hope this helps, although it looks like this is an older question. I hope you have resolved it.
Oct 12, 2008 | Palm TX Handheld
Palm Treo 650 Unlock Code.
Call your service provider.
Jul 16, 2008 | Palm Treo 650 Handheld
Treo 650
my treo 650 just turned of the light of the screen.thought it was only battery.i pulled out the battery then put it back again,the light is on and say palmOne with a bar loading.then the light was gone again.try to sign on but nothing does
Jun 24, 2008 | Palm Treo 650 Handheld
Treo 650 Problem
probably dodgy software conflict. Try taking battery out and leaving for anhour or two then take out sim carrier. Put battery back and see if it starts properly. If not looping put sim in and try to switch phone on. if this works then there is a problem with software you have loaded so switch off back up before you sync. Then once you have synched the phone add back applications one at a time until you find the one that causes the problem. Of course you have to do it all over again once you have found the culprit!
Another cause, if you have attempted to upgrade the firmware, is a failure of the upgrade process. if you can't get this to work I am afraid the phone is bricked and needs to go back to Palm for repair.
Kevan ;-)
Nov 19, 2007 | Palm Treo 650 Handheld
Pls help me for power on fail
If your Treo loops or freezes during a soft reset, a system reset may help. Performing a system reset allows you to get out of an endless loop in order to uninstall a third-party application causing the looping: 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. While pressing and holding Up , use the tip of the stylus to gently press the reset button on the back of your Treo. 3. When the Palm Powered logo appears, release Up . 4. Delete the third-party application that you suspect is causing the problem. 5. Perform a soft reset. The wireless features of your phone are not available until you complete this step. Good luck!
Nov 23, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
126 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
