Saving Data from harddrive before reformatting
How can I make a harddrive a slave in another computer to save data files?
  • gannmeister May 21, 2008
    thanks for replying, but i've opted to just go ahead and reformat/partition harddrive. A suspected virus, and I didn't want it to possibly infect my harddrive.
What kinda drive? SATA? IDE?SATAII?
older drives have pins at back, select jumper for slave. SATAII u can try to do from BIOS (DEL at startup)
Posted on May 21, 2008
How can change Vostro 3300 32bit- 64bit
You'll have to reload from scratch (not upgrade) a 64-bit operating system, such as Windows 7. Make sure the reason you think you need 64 bits is worth the time and effort of:
1. Saving ALL your Data Files before you start, perhaps to an external HDD, a USB flash drive or a network drive.
2. Saving backups of all your applications -- electronic banking, Email, Address books, etc. (Outlook data files)
3. Reformatting and reloading a new OS (you'll probably have to buy it).
4. Reloading all your applications (make sure you have ************, serial numbers, etc.
Unless you have a new mission-critical app that requires a 64-bit OS, I'm not sure you'll be happy with the outcome. The PC probably won't perform any better than it does now.
Apr 02, 2017 | Computers & Internet
A computer won't boot.
iam sure that if your windows wont load and you can not get it to start you may have to put your hdd to another computer using a usb drive,or add it to another computer as a slave,or when putting new xp on see if it will let you keep your files.
Apr 14, 2015 | Computers & Internet
Hello! when i press the shutter button, it makes 3 beeps and doesnt take any video or photo even if there's enough place. what can i do?
I found out that my GoPro was saving data on the card that was not in any file. If you have lost data, when the camera runs for a while and the PIC file shows zero K, then when you delete the file, the random data stays. I got the first few minutes of a couple of sessions, then the camera shut down. Put your card in a card reader on the computer and right-click and check the card for usable space. You might find that it's full of random data not assigned to any file. Then you have to reformat the card to clear it. Just deleting any PIC files so it says 'no files found' doesn't mean the card is cleared.
If the card has space, you have some other problem, sorry. But I regularly reformat the cards just to make sure they are clear after deleting files. The GoPro doesn't care, it just thinks it's a new card and inserts it's file routine.
Aug 07, 2011 | GoPro Digital Hero 3 Digital Camera
My Acer X1700 desktop randomly gives Blue screen and locks or sometimes reboots. The error shown on blue screen dump says some like "a prblem has been detected and windows has been shutdown to prevent...
Your hard drive is corrupted - virus, bad driver file, etc... You may need to reformat and re-install Windows or operating system. Before you do that, remove the harddrive and "slave" it on another computer to backup you data. The other computer should be able to discover the corrupted harddrive allowing you to do the backup. Then you can proceed with the repair or reformat.
Oct 24, 2010 | Acer Computers & Internet
Why can't I copy larger files than 4 maybe 5GB to my passport WD? Is there a quick way how I can change this?
Your disk is formatted using FAT32 file system. FAT32 has a maximum single file size of 4GB. Reformat your drive using NTFS file system to enable file saving larger than 4GB.
To reformat the drive:
-insert external drive
- open "My Computer", point your mouse over the drive letter of your external drive, right-click and select "Format". Select NTFS from drop-down menu under "File System".
-click "Start" button
Please note that all data will be deleted so please backup your files before formatting the drive.
Aug 25, 2010 | Western Digital Passport WDXML800UE...
Problems with my hard drive
You should be able to slave the old harddrive to the new one regardless of manufacturer. In the event that the drive is not "browseable" via Windows explorer, you should still be able to use DOS commands to copy the data files from the old harddrive to the new one.
Mar 27, 2009 | Computers & Internet
Help
This kind of device its usually a plug and play thing. are u using it as a slave or a the master disc?? make sure the that u plugged it in the right spot, and that the jumpers are correctly positioned. if this isn't your problem, i would recommend doing a zap on it, and the formatting it
Dec 27, 2008 | Computers & Internet
How does SanDisk 2GB allow save to?
Some USB sticks have a little switch on the side of it to "lock" the data, this makes all data read only make sure yours doesn't have one or that it is in the unlocked position.
If you want to reformat the stick, plug it into the computer, go to my computer, then right click on the drive letter and go to "Format". Pick "FAT32" as the type of file system and format.
Jan 26, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
USB Mass Storage
Try opening some files saved in your usb. Example if you have files saved in excel format, open your excel program then click in open files and select files saved in your usb. You will be able to open the files in excel using this method. You can do the same for any file you want to open. The downside is you cannot open the whole usb file and navigate or explore as usual.
Dec 04, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
