Back to:
Tags:
Kenmore 4292x Front Load Washer
Replacing water valve on my Kenmore 45992 washer
posted by terrijo413 on May 21, 2008
Can you send me instructions on the above
Comment by terrijo413, posted on May 29, 2008
Not yet. My husband hasn't had the time to work on it, so I'm turning the water on and off manually right now :).
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 23, 2008
Not Rated (0)
watugot
Rank:Guru Guru
Rating: 94%, 313 votes
Remove the 3 screws at the rear of the machine holding the top. The top will slide back and lift off. Remove the hoses to the machine and the hose from the valve that goes to the dispenser. Unplug the wiring connectors from the valve. Remove the screw holding the valve to the rear panel of the washer and remove the valve.
Post back if you have any questions and I will answer as soon as I can.
Thanks, Mike
Comment by watugot, posted on May 29, 2008
terrijo,
Just wanted to follow up on your washer problem and see if you got it fixed.
Thanks, Mike
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Replacing water valve on my Kenmore 45992 washer:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Washing Machines
el suiche de la lavadora se me dano el de la puerta de...
Hi, I want to soak a load of towels in Borax before I wash...
Error F02 then Sud then F02 again and beeping. Door locked...
I have had this washer for almost 4 years and all of a...
I've owned the washer and dryer pair for about 6 years....
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
