Ricoh c410dn sc307
Where can i find the description of service code 307 for a ricoh aficio c410dn?
I haven't found anything on the ricoh site.
thanks for the help.
That crosses over to the Lanier LP226cn.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions:
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power 1
1. Check the connectors.
2. Replace the PCU for yellow.
3. Replace the drum positioning plate.
4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
- Lanier Tech
Posted on May 21, 2008
    New Friend:
Error code sc 307 riacoh aficio sp c410dn
Posted on Apr 21, 2015
I have an Aficio SP C410DN with error code SC361. Any ideas what that could be? thanks.
Hi, SC361 is a Toner Density error in the Magenta PCU. Your best bet is to replace the Magenta PCU.
You could go in to the service menu, if you now how and do a TD Initialize on the magenta PCU - Service menu 3.801.004, but it may still not resolve the problem.
Go with the 1st, hope it helps.
Dec 27, 2010 | Ricoh Aficio SP C410DN Laser Printer
The Aficio SP C410DN is compatible with these other printer models:
- Aficio SP C411DN
- Aficio SP C400DN
It is also similar to the Aficio CL4000, but some of the parts may be different.
Sep 02, 2010 | Ricoh Aficio SP C410DN Laser Printer
I Do not have the Instulation cd for my Ricoh Aficio SP C410DN and I am struggling to know what driver to install. Please help
All the documents that you will need to install the printer and the drivers are available at the Ricoh support site here.
Please post a comment and rate the solution. Happy to help further if this is not sufficient.
Jun 11, 2010 | Ricoh Aficio SP C410DN Laser Printer
Hi all, I have a problem with a Ricoh C410dn , the error code is SC396, what does it mean ? Or do you know where to get a service manual for this printer ? Thank you very much
sc396 is an overload error for the black drum motor. You can try removing and replacing the black drum and making sure nothing is obstructing its movement (like a scrap of paper stuck somewhere or a chipped gear). You might want to have a service technician take a look at it if you can't find anything, to see if the motor needs to be replaced.
Jun 04, 2010 | Ricoh Aficio SP C410DN Laser Printer
Reset photoconductor units aficio 410dn -
in order to reach the Ricoh restore factory menu, you need following steps.
1. push the yellow small "C" buttom. you can hear beep.
2. push the 3 numeric buttoms, in following order: 1,0, 7 .
3. push the big red "C" buttom, don't release for 5 minutes until you saw a copy windows popup on the screen.
choose the "copy sp", then trun off the power, and turn it on again.
now done, you have reseted the factory settings for the Ricoh Aficio munti-functional copier;printer.
If you really need the actual "Chip" then you will have to get a Service manual, inside there are circuit diagrams and circuit details.
May 06, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Aug 16, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
Mar 26, 2009 | Ricoh Aficio SP C410DN Laser Printer
1,536 people viewed this question
