Question about Samsung Yepp YP-T9 Digital Media Player
Help my YP-T9 DIGITAL MUSIC PLAYER IS SAYING BLUETOOTH MODE HOW CAN I GET THIS OFF AND LISTEN TO MY MUSIC AGAIN?
    Problem Solver:
  • 5 Answers
Have you tried going to the bluetooth settings, and turning it off from there?
Posted on Jun 11, 2008
I have a samsung yp-t9j mp3 player. the probelem is that i,m not able to install the samsung digital media player as it is not compatible with windows 7. please help
Use Windows Media Player to download music to your Samsung YP-T9.
It works as well as the Samsung media player...
This is a free answer, please rate me
Oct 16, 2010 | Samsung Yepp YP-T9 Digital Media Player
My samsung yp-t9 says automatic test!!!HELP!!!!!!!!!!!!!!!!!!!!!!
Try pressing the menu and the record button together at the same time.This resets the yp-t9.I guess this should help.
Jul 06, 2009 | Samsung Yepp YP-T9 Digital Media Player
I want to reset my samsung yp-t9
Complete Solution - includes fix for Bluetooth.
You will need to execute a number of steps to do this:
1 - obtain a copy of the latest firmware from http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=mp3others&subtype_cd=&model_nm=YP-T9&dType=D&vType=L&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-T9
or (even better) - go to the international site and download a copy of YP-T9 V1.80.zip
2 - Reset - Power off the yp-t9 using A-B and MENU pressed together - hold down A-B and press the POWER button to enter the low-level format mode - press LEFT LEFT RIGHT RIGHT UP CENTRE DOWN - the yp-t9 will now reformat - power off using A-B and MENU together
3 - reload firmware - Power on normally and connect to PC as a USB drive. Move the two files you just downloaded (MUON.ROM and SYSDATA.BIN) into the root of the USB drive - Safely remove the drive - Power on the yp-t9 and allow it to re-install the firmware
If you want to restore Bluetooth functionality you will also need to perform the following steps:
4 - pop the four rubber plugs out of the back of the unit - with a small phillips screwdriver remove the four screws - insert your fingernail into the seam of the unit on both sides and pop off the back - gently (slowly) remove the battery taking care not to place any strain on the connecting wires - copy dowm the 12-digit number on the label under the battery (starts 0016xxx...) - replace battery, back, screws and plugs.
5 - using text editor create a file with the 12 digits (use upper-case letters where appropriate) followed by <enter> key - save it as BT_MAC_ADDR.TXT
6 - connect the yp-t9 and open it using Right click on Start and Explore - find the yp-t9 and drag a copy of BT_MAC_ADDR.TXT into the SYSTEM folder - Safely remove - power on normally.
Hope this helps
Chris
Nov 19, 2008 | Samsung Yepp YP-T9 Digital Media Player
Completely wipe a yp-t9 2gb
to get rid of songs you must go to mycomputer and look for
a mp3 icon click it.After that click on music and then right click and delete the songs you dont want
Apr 06, 2008 | Samsung Yepp YP-T9 Digital Media Player
My player is stuck on bluetooth mode.
I'm having the same problem....
Bluetooth mode appears every time I turn on my MP3 player and it's always necessary to turn off using menu+ab button.
Somebody uses info from this forum:
http://www.anythingbutipod.com/forum/showthread.php?t=11933 Unfortunately this didn't work to me...But if you want to try...good luck!
Jan 26, 2008 | Samsung Yepp YP-T9 Digital Media Player
Samsung YP-T9 corrupt files
Go to the settings menu in your yp-t9.Then open the system menu.Then update the library.The files will go after this.Guess this helps.
Jan 18, 2008 | Samsung YP-T8 Digital Media Player
Blue tooth mode
go to meny, bluetooth, bluetooth mode, and select off.
Nov 17, 2007 | Samsung Yepp YP-T9 Digital Media Player
Samsung yp-t9
i cannot down load driver from your site for my ipod which model no-is yp-t9j and it capacity is 2 gb .
please give me advise how should down load this driver for my pc.thanks
May 29, 2007 | Samsung Yepp YP-T9 Digital Media Player
Samsung Yepp YP-T9 Digital Media Player Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
