Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
F0 display error
The oven display is saying F0 and flashing locked Door. I can hit the start button and it shuts off for a minute, and then starts beeping again. The door opens, but I'm not sure why it's doing that. I haven't tried unplugging it yet though.
  • Kerobous May 21, 2008
    It was saying F0 and flashing the locked door and beeping again.
  • robert samples May 11, 2010
    turn the breaker off for 30 seconds then turn it back on watch it for 1 min see if the code resets then reply to me
    President:
  • 1,314 Answers
Ok fo is a communications error and can be in three places the manuel says replace the eoc but ive found that's not always accurate if this is a free standing or slide in range you can pull it out and remove the back top and bottom when the oven goes in self clean the door switch has two functions when the door is open it tell the clock that the door is open and the door latch motor and it turns on the oven light when the door is closed it turns off the oven off and tells the clock and latch motor the door is closed it does this by two micro switches on the latch motor one for closed one for open by means of a plastic cam on the latch motor now if you have self cleaned the range lately then the door locked micro switch may have stuck when the cam rotated back to the unlocked position and with both switches closed the eoc wont let the oven work because it thinks that its in self clean also ive seen mice build nests on the platform that the motor is mounted on and pile insulation on the closed switch and close it that way so you got the door switch the latch motor switches or the mylar ribbon that goes into the eoc its self could be dirty now on the clock or eoc there is a little lock tab at the bottom of the ribbon that you pull up and release the ribbon and gently clean the ribbon and replace it now when testing the switches with a ohm meter you must remove one wires from the switches to prevent getting a false Reading if all this fails then replace the clock now you can call a repairman but most like they will replace the clock without checking the other stuff now is this a free standing range also some where on the range will be a tech sheet with wiring diagram ans stuff it will help you is this a freestanding range or a slide in as componets are located in different places if you need more help reply to me
Posted on May 21, 2008
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F7 Shorted Touch Panel Replace Glass Panel
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F2-E0 Shorted Keypad Replace Keypad
Ovens with 2 Digit Displays
Dec 18, 2009 | Ovens
Pushed the clean button, the oven locked, and the screen started beeping and flashing f9 or f7. I hit cancel, and the oven is still locked and the clean button is sill flashing.... It has been 10 hrs!
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^%$
Jun 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F0 error code on ge profile oven
Could be a stuck keypad. Try pressing all pads at random several times each to clear it.
If that does not work the ERC(clock) must be replaced.
May 26, 2009 | GE Profile JTP18 Electric Single Oven
GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
GE JGBP80 oven shuts off and the locked door light flashes
That's awesome! I just found this site on Christmas day minutes away from family arriving and I had exhausted the manual for help. Under the troubleshooting section of the manual it lists "door Locked" light blinking as a problem with the only solution being - "shut the door." With three dishes in the oven that didn't help!
I took the advice of the site and wiggled the actual door lock on the inside of the oven and that didn't work right away either.
I had to trick the oven into thinking the door was shut by pressing the sensor on the right hand side in and then turn on the oven cleaning cycle with the sensor held down. After the lock activated and moved across with the door open, I had to hold down the door unlock feature and wiggle the lock as it unlocked. A little more complicated, but none the less it worked!
It must be a sensor inside the locking mechanism that isn't reading the lock being open - or something...
Dec 08, 2008 | GE Profile JTP18 Electric Single Oven
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
F0 error - My GE Over displays an F0 error & constantly beeps
Appu, the F0 error for this built in means there is a shorted or stuck off key. Sometimes this can be resolved by removing the keypad ribbon cable from the board and cleaning the ends with an eraser. If that doesn't work, you want to find out whether its the board or keypad by ohming the ribbon cable, 3 to 4, probes on the conductor side...should read 125 to 1750 ohms while pressing the off key. Catriver..post back.
Apr 29, 2007 | GE Profile JK915 Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
124 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
