Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Some data missing
When i right click and see the properties of my usb it shows 1.5 GB but when i open it it show only 1 mb data so what should i do?
If it is not important data please format the drive .............
actually when virus attacked to pen drive it shows like that.....
Posted on May 21, 2008
I have an 8 GB Verbatim Store 'N' Go USB Flash Drive with all files delete and the flash drive show only 532 MB free of 7.45 GB. Something must be hidden that I cannot delete. Help please!
The message means that the of data on your drive 7.45 gb with free space of 532 mb which means that you have 7518 mb of data installed on it.
w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive then you restore it to its default status Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 You might have to alternate doing this repeatedly until the problem is resolved Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system.
If you need more help with this post a reply Hope this helps.
Dec 20, 2012 | Computers & Internet
My 8 GB Kingston Flash Drive shows only 4 MB space. Plz help
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
restore defaults
In XP
you might have to alternate doing this repeatedly until the problem is resolved
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
if you need more help with this post a reply
hope this helps
Oct 08, 2012 | Kingston Flash Memory DT101N/8GB 8GB...
Cannot see my Data
restore defaults
In XP
hope this helps
Sep 30, 2012 | Dane-Elec DaneElec 1GB USB Drive Red 1 GB...
I have Kingston Data Traveler size 4 GB, Now it become write protected and never allow to format. Further, it shows skymedi instead of Kingston. Please help me.
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7 this will also apply to usb drives
right click on your usb drive select properties select sharing then select advanced sharing make sure there is a tick in the share this folder box
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F: D: or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
another way:
click start all programs accessories open windows explorer click on my computer you should see your drive click to open it also right click select send to desktop to make shortcut
click start click on my computer you should see your 4 GB data it might be listed as a mass storage device
right click then select format
another way is to control panel administrive tools computer management disk management right click on your -GB data traveller select format
hope this helps you
Sep 14, 2011 | Kingston Technologies 512MB DataTraveler I...
Drive appears corrupt. Sometimes every folder appears empty yet the properties shows 3/4 of the drive is still used (120GB). I could access the drive 2hrs ago but now it has dropped of the scene - can't...
try to error checking disc. connect your usb drive to computer then right click, open the properties. there will be tab for 'tool', click it. there is option for error checking, click 'check now'. wait till finished recovery then open the drive again. if the data still missing maybe there will be hardware problem or it can be a virus too. hope this useful, regard riyan.
Mar 03, 2011 | Maxtor Basics Personal Storage 3200...
How do i remove write protection from my kingston datatraveler G2 2GB? thank you for your assistance
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click permissions
hope this helps
don
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Not able to transfer file onto the external hard drive
IBM 40 GB usb HDD When plug in then Drive icon show but data can not show. Drive properties shows 0.0 Mb
Dec 08, 2009 | Western Digital My Book Home Edition 500...
Cannot delete stored music files
format it by connecting to pc
right click on it ok
Oct 19, 2008 | iLO (2 GB) MP3 Player
Verbatim usb drive 8 gb help
Microsoft Windows 2000 help Processor:, Intel Pentium 133 MHz or equivalent 8 CPUs Supported. Memory:, 256 MB. Drives:, 1.0 GB Disk space CD-ROM / DVD drive ...
Computer questions and answers listing 200 - 299 CH000273, Not able to see over 8.4GB hard drive. CH000274, Not able to see or boot with hard drive over 33.8GB. CH000275, Unable to see over 8GB with ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
63 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
