Question about Casio EXILIM EX-Z70 Digital Camera
Camera lens might be broken
I dropped my camera at an event. The screen is fine, but when I take pictures all I see is fuzzy, white lines, and actual picture has a pink hue. If my camera lens is broken, how can I get it fixed?
My friend droped my camera and the lens is sideways. i can look at my pictures, but when i want to take a picture it is black and says lens error. what should i do?
Posted on Jun 13, 2008
Fuzzy Pictures w/ Nikon D3000
If this is a new camera, it should still be under warranty. I suggest you contact Nikon before doing anything else to determine if the repair would be covered under warranty. Nikon also would be in a position to advise you as to what the problem might be so that in the event that the repair is not covered under warranty, you don't replace the wrong thing.
Feb 07, 2013 | Nikon D3000 Digital Camera
Pictures fuzzy when you look through the viewer.
The viewfinder and the picture lens are totally separate. If it looks fuzzy, and then comes out fuzzy, the capture screen inside needs cleaned. The main lens and viewfinder lenses should be cleaned too.
Get estimates before you say yes to the work. It might be cheaper to buy another camera, unless you can do the work yourself.
Aug 06, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
:( please help - lens problem
time for a replacement camera...as the repair wouldn't be to expensive to consider.  Use your wrist strap
Apr 01, 2009 | Casio Exilim EX-Z30 Digital Camera
White and fuzzy screen
Hey mea411,
What you should do is have the camera looked at by an authorized service technician. There is most likely something wrong with the LCD screen itself. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 19, 2008 | Kodak EasyShare C613 Digital Camera
Fuji Finepix camera fault
Dropped, that's rough. As far as the lens goes, it could be damaged or jammed. The LCD however sounds broken, once the seal is lost the display needs replaced.
In any event, these are not battery related issues.
liveoutside
Jul 04, 2008 | Fuji FinePix S5000 Digital Camera
A brokem screen
LCD is broken and needs to be replaced.
Jun 15, 2008 | Sony Cybershot DSC-T200 Digital Camera
Kodak easyshare DX 7630 screen black in take a picture mode but is fine in review etc
Hey Wistra,
You could try resetting your camera to the factory settings by choosing the reset to default setting in the menu. If this doesn't work the sensor on the camera is most likely broken, and you should have the camera looked at by an authorized service technician. If the camera was purchased less than a year ago the repair would most likely be covered under manufacturers’ warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Kodak EasyShare DX7630 Digital Camera
Help! Dropped my Candon Powershot SD600 Digital Elph.
replace the motorized lens and you should be ok. You have to buy a duplicate Parts camera from Ebay to have the part to fix yours.
Mar 15, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Lines on screen
Hi, I have the same problem with my sony DSC-S700. I think someone drop it, and it took pictures with horizontal line specially outdoor. I noticed that the lens shutter does'nt open and close. All I did was to tap on the lens several times and everythings back to normal. I so happy my camera is working again. Thanks to your idea. Brenton
Sep 24, 2007 | Kodak EasyShare Z612 Digital Camera
Casio EXILIM EX-Z70 Digital Camera Logo
180 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
