Question about U.S. Robotics MAXg USR5461 (738168036790) Wireless Router
Interface will not come up to configure router
I have made sure that all cables are connected correctly. and then when I get to step 2 to configure the router , the web user interface will not come up. when I called us robotics to ask for assistance they said they could not help me since it is out of warranty. whenever I type in the address 192.168.2.1 , a page comes up saying I am working offline,. it will not open the interface wizard. I have tried to reset the router and still the same problem.
  • sansonemena Sep 23, 2008
    non riesco a connettermi con wireless solo tramite cavo ethernet
  • Anonymous Sep 24, 2008
    My router was working for about 1 year and 8 months and suddenly it stopped working. I tried to reset it but still no wireless connection. I cannot even access the default 192.168.2.1 webpage. When I try to connect it using the ethernet cable I get limited or no connectivity and still cannot access the default configuration page.
  • 50 Answers
Use pin-hole to reset router. Try default 192.168.1.1
Posted on May 21, 2008
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
I cant connect to the internet
How to quickly install and use your Belkin wireless G router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jun 10, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
INetwork Password
ask your internet service provider
May 30, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Modem router(quest gateway) works on one computer but won't connect to two other computers. was working on two ,and now only the one wired to it.
1. Step 2
2. Step 3
3. Step 4
4. Step 5
May 11, 2010 | 2wire (1000-400108-001) Router
How to change password
1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
May 10, 2010 | Belkin (F5D7230-4) Router (587009)
I have a wireless router i can get it working right?
How to quickly install and use your wireless router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Apr 26, 2010 | Airlink AR430W Wireless Router
I need to enter my code
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Apr 23, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
Jan 18, 2010 | Cisco ASA 5505 Firewall
Can i connect my xbox to my laptop /w pc usb
Xbox Network Connection using Hub
This is the most common network configuration and is also the easiest to setup.
Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
**NOTE** A switch may be used in place of a hub with the same basic setup.**
That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
Xbox Network Connection using Router
This is another common network configuration.
Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
**NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
That's it! Your Xbox is now on the same network as your PC
Xbox Network Connection using Crossover Cable
This is the last network configuration. For this setup you need at least one NIC card.
Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
**NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
That's it! Your Xbox is now on the same network as your PC.
Aug 14, 2009 | Video Game Consoles & Games
How To Set Up PPPoE DSL Connections with a Linksys Router
This article describes how to manually configure a Linksys Router for broadband DSL that uses PPPoE (Point-to-Point Protocol over Ethernet) for authentication. For automatic configuration options, please try: 1. Linksys Easy Connect (see Answer ID 1650 for more information), or 2. The Linksys Setup Wizard CD-ROM software that came with your Linksys Router. Simply insert this CD-ROM into an online computer before connecting your Linksys Router, and the Wizard will provide step-by-step instructions on how to install and configure your router. If you are unable to set up your Linksys Router by using one of the above options, use the steps below to manually configure your router. NOTE: It is recommended that you print this article for offline reference. STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Open Questions:
U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Logo
178 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
