Question about Refrigerators
Refrigerator light whirlpool designerstyle
How do you remove the bulb that has burned out. its a whirlpool designerstyle with the freezer on the top. The recepticle for the bulb is really weird its white plastic and has a ridge on the backside. Try as I might I cannot get the bulb to unscrew. Is there some other way that it is supposed to be removed? Seems kinda silly to call a service man for a light bulb change. I don't have a manual. the refrig was in the house when I bought it. any help is appreciated
    President:
  • 1,314 Answers
Well there is no magic button to push or anything like that some times they get stuck in those plastic holders get a pair of work golves or heavy towel and unplug the unit then just twist it out if the bulb seperates from the base get a pair of needle nose plires and grab it by the base and twist it out
Posted on May 21, 2008
Where is lightbulb in freezer whirlpool model ed5kvexvboo
The model number is probably ed5kvexvb00. The parts diagrams, http://www.searspartsdirect.com/model-number/ed5kvexvb00/1198/0165000.html , show four places with light bulbs. There is one light under the Refrigerator ice dispenser. (It's mounted on the Refrigerator Dispenser Motor Mount. The motor power a shaft through the ice bucket so that might block your view of the light cover.) There is a small 7 W light behind the dispenser control bracket. There is a single light near the top right of the freezer above an air duct clip. Finally there are two bulbs in the refrigerator above the air duct louver in the lower portion of the refrigerator. Use the Refrigerator Liner, Freezer Liner, Motor & Ice Container Parts and the Dispenser Front Parts diagrams above for pictures of the covers for several of the bulbs.
I hope this helps.
May 29, 2017 | Whirlpool Refrigerators
Whirlpool oven designerstyle
Most likely the control / clock has gone bad or possibly a burnt or loose wire connection
Nov 10, 2017 | Whirlpool (ET8FTEXSQ) Top Freezer...
My whirlpool fridge similar looking to Whirlpool GR2FHMXV Top Freezer Refrigerator has been making a big bang noise many times in a day. Tonight it has a burning smells. Please advise?
the banging and crackle noise can be from the defrost element in the freezer side as it heats up it melts the ice on the evaporator it can be a bit nosy. there shouldn't have a burning smell tho get it checked out
Feb 04, 2011 | Whirlpool GR2FHMXV Top Freezer...
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Refrigerator section does not cool. Light or LED behind refrigerator control knob does not light so you can not see the current setting. Freezer section works fine as does the freezer control knob light.
these refrigerators are notorious for a bad main/mother-board being bad,especially if recently you had light bulbs have burned out in the refrigerator compartment as this creates a surge on this board and burn the printed circuit trace on the board,it is located in the lower rear of the unit and is housed in a plastic case and if you open the case and look at the board and case there will be a burn spot on the plastic case also
Mar 13, 2010 | GE GTS22WCP Top Freezer Refrigerator
Refrigerator not working, freezer stll works
if you recently had light bulbs burn out in the refrige section and now the digital temp read-out is also dark,it will be your control board (motherboard) needs replacement as the bulbs burn out it causes a surge and ruins this board,its located in the lower rear area on the left lower wall in or on the inside back in a plastic case,open the case unplug the wire harnesses and remove the board,it will have some circuit trace burned and the plastic case will be discolored there
Feb 14, 2010 | Refrigerators
Changed bulb in frig and light still not on. Frig is older whirlpool. est age is 15 years. i thought bulb was just burnt out. everything else still working. replaced old bulb 15 w with an "appliance" bulb...
I would stick with an appliance bulb. The glass in those is more resistant to extreme temperature changes.
Your problem sounds like it could be that the door switch has burned/corroded contacts.
If you have a continuity meter you can remove the switch and test it to see if it's working.
BUT, FIRST, TURN OFF THE BREAKER TO THE FRIDGE!!!!
If you don't get continuity thru it, soak it in rubbing alcohol for about an hour. Let it dry for about an hour, and test it. If it's still not working, replace it.
If you need help with the continuity testing, let me know.
Apr 30, 2009 | Whirlpool ET8MHK Top Freezer Refrigerator
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Conquest light is flashing and clicking sound
With sounds like that I would use caution if installing a light bulb there. The sound and description sounds like a short circuit. Did this happen recently? Could you get me the complete model number, for example GS6SHEXN
Let me know, Thanks Sea Breeze
Mar 14, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool gold refridgerator light not working and is making funny noise
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
153 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
