Question about Panasonic PT-52LCX65 44" HDTV
Projection defect I have a small projection defect (looks like three sets of very small horizontal lines [approx 1/8in long and in group vertically - about 3/8in high for all three). Shows up most when a black background - appears to be color sensitive. It does not appear to be the screen itself. Need to determine how to kill the color guns (two at a time) to see if I can tie it to one particular gun. Bill Lynch tb85310@qwest.net
  • 927 Answers
Good Day;
It sounds like you may need to re-adjust your G-2 controls, located at front, remove front panels. Look for small block with screen /focus controls on item, first turn color down, reset brightness, contrast controls. Adjust until lines are at min. and picture is a good black and white (grays). Good Luck, big IRISH.
Posted on Sep 09, 2008
Sound no picture 56h80 toshiba
This set will blank the picture for several different reasons:
No filament voltage to the three tubes it uses.
No high voltage to the three tubes it uses.
No vertical or horizontal sweep (prevents all three tubes from having the screens burnt with a line.
Some of these can be tested but most require a schematic etc.
Set has several fuses and some do not look like fuses--called pico fuses.
Jun 11, 2012 | Toshiba Televison & Video
Mitsubishi VS-55609 top left screen has folded over
chk for any electricity or magnetic interferanc. change the location to the TV. switch of the tv fro 5 min and restart it again back.
Jul 03, 2008 | Mitsubishi VS-55609 55" Rear Projection...
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
I have a vertical line in the middle of the tv it has what looks like pictures how do I resolve this at home
hi there, seems you have a defective Vertical IC. If you can locate this 8-10 pins mounted on heat sink and has label LA 7837 or alike. try to replace this. defective vertical IC somehow manifest as horizontal line in the middle of the screen. it has picture but cannot adjusted to occupy the whole screen. Hope this help, please rate and vote. good day
Mar 26, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Three coloured lines appered on the screen - no picture
    If there is no picture and 3 vertical lines in the center of the screen, stop. Turn off TV. You have no horizontal deflection happening. Lines will burn into crts and be permanently visible after repair.
    No horizontal deflection is caused by Horizontal sweep circuit failure, maybe flyback transformer and associated components. More than a simple do-it-yourself repair.
    easyab
    Apr 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
    Only getting vertical lines on screen..no picture
    Tell me are they Verticle lines or verticle LINE. If it is one line, either yoke( a coil kept at the neck of the tube).A yoke has two coils for Vertical and Horizontal for deflections.When the Horizontal deflection coil is opened you get a vertical line which is a single bright line. There another small linear coil on the board connecting the horizontal coil of the yoke.This is a simple fault and tracing is very easy and not expenssive.Only if the yoke is open, it might be bit costly.And that is a rare case.
    Aug 02, 2009 | Mitsubishi VS-45607 45" Rear Projection...
    Samsung HLP5063W - Vertical Lines
    It's realy bad guys. It looks like DMD defective. If I could see a picture...?
    Dec 03, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
    Lines on tv
    Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
    I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
    White horizontal line (no vertical deflection)
    Check / replace R548, R549
    Sound but no picture except for a couple of horizontal colour lines
    Replaced the frame chip TDA8356, set now ok
    Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
    Pioneer projection TV vertical lines on screen
    do you have full picture and did this set have any faults before this,possible image burn on crts.from previous horizontal fault.
    Aug 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
    Panasonic PT-52LCX65 44" HDTV Logo
    90 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
