Question about HP Office Equipment & Supplies
Printer my printer prints fine except at the last it will not release the paper and just makes a noise
I m sanjay i want to give u a suggestion.
1) pls open the printer and then remove the cartidges colour and black both.
2)After that clear the cartidges these cartidges with the cleaners as example coling, kiwi kleen etc
but keep a care
after this cleen the mouth where from the inks are come out after this replace your cartridge and then replace your cartidge afetr this follow the next
open the back side of your printer and then you can see a pipe clear this pipe and after this clear the aboves roubber's pipe after this close the back sides cover and then use your printer i thinks that after following these process you can't get any problem.
Posted on May 21, 2008
HP Photosmart C6280 All-in-One making weird noises
this is hope, i had this problem once. what it was was a small piece of paper that was caught in the rollers. i know you said this, but check again, I am almost positive this is your problem
lastly, check the black cartridge, take it out make sure nothing is stuck to the ink dispensary for clear printing
hope this helps and good luck
Apr 29, 2010 | Office Equipment & Supplies
Cannot empty the print que print jobs on IMac status is Deleted, except for last line which says "printing", but it is not printing
This is most likely because an error with the printer is making it impossible to delete the final print job. The most common error is no paper or a paper jam. Look for blinking lights on the printer and any error messages. Feed more paper if necessary. Once you fix the problem, reset the printer or press the blinking button.
Feb 21, 2010 | Dymo LabelWriter Thermal Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
Problems printing 4x6 with MP600
You're most welcome. Remember to check all of your paper, I had it curl a bit from sitting too long and I had a very bad paper jam from that. Good luck!
Feb 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My CX4200 is printing very close to the left edge of the paper.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Epson CX4200 All-In-One PSC Printer
CX11NF noise
It sounds as though the noise is coming from you fuser assy. this is the last thing that touches the page before it exits the paper path. The most likely scenario is that the bearings in the fuser are gone and you will need to replace the fuser. the fuser retails for about $450 au.
Gremlin11
Sep 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
Printer not work
My printer will print on every type of paper i set it to in the preferences, except "plain paper". the machine also doesn't copy when set to plain paper also. I printed a report cover on matte paper which printed fine, but when i change back to plain paper, it doesn't print.
Dec 18, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Loud clicking noise
This is one of the known issues with the HL-5240. This will require a replacement paper tray. Definately the problem if it is more of a clack than a click.
Sep 18, 2007 | Brother HL-5240 Laser Printer
69 people viewed this question
Ben Johnson
