Question about ASK Proxima Proxima DP2000X Multimedia Projector
Optma ep 750 projector
I have a projector that won't come on...has a new bulb... but just completely dead...nothing working...any suggestions?
Thanks, John Davis
  • 2,237 Answers
Replace the power supply.
Posted on Nov 10, 2009
Hitachi 1350 projector dead, no power. cleaned everywhere, changed the bulb, nothing I do gets power into it.
I assume the projectors are of similar age and have similar useage history? Not certain why they would fail together, but the most probable cause is faulty switch mode power supplies. The electrolytic capacitors in these supplies a relatively short working life, especially when installed in high temperature environments - like a video projector. new caps in the supplies may be all that's required to solve the issue. If you have other similar projectors, they may well be approaching the same problem.
Any reasonably competent TV repair tech should be able to check the supplies for you, and repair them if found faulty :o)
Apr 05, 2014 | Hitachi PJTX100 Multimedia Projector
High temp light on when powering up
Remove the screws and check out the fan's working state.
EP759 have one big 92mm fan for the lamp, and three small, near 40mm, fan's for the optics.
Power of the bulb is very high, so just 1 broken fan can make that situation.
Apr 25, 2009 | Optoma EP759 - HDTV Compatible DLP...
HP VP6210 won´t turn on at all
try to replace all the capacitors on the motherboard. This are the only parts that leak in time. Try otherwise to reset to counter or update the firmware on your machine on the infocus site.
Goodluck !
Sep 04, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
the fuse (if it has one) is on the power supply next to where the plug plugs in. if the fuse is ok, replace the power supply.
Jul 18, 2008 | Office Equipment & Supplies
Sanyo PLC-XU58 projector completly dead
I had the same problem and the technician diagnosed as being caused by a faulty Ballast which he said caused the bulb to fail. He didn't test the bulb but his experience indicates that even if the bulb was not blown it would have been stressed and it would only be a short time before it fails completely.
When these fail there is no real reason for it it seems but it has been suggested that a probable cause could be not cleaning the filter, at least every six months. The result of a dirty filter would be overheating and this could be the cause of the failure.
Jun 05, 2008 | Sanyo PLC-XU58 Multimedia Projector
Projector Doesn't Power-ON
Hi bmosai
Yes you will have to replace the lamp.
The Projector will shut down and stay off as a safety feature.
May 04, 2008 | Panasonic PT L711U Multimedia Projector
Hp VP121 needs new bulb?
Hi there
Take out the lamp and check for any marks on the inside ( shaft ) of the lamp. If there is marks or discolouration on it then you can be 100% sure it is the lamp.
Apr 10, 2008 | HP VP6121 Multimedia Projector
No power
Bulb is definitely not cause of your problem.Normally lamp light will blink when it's defective.Dead means PSU problem .Some projectors have a overheat switch which switches off supply till manualy reset,you need to open the projector.
Oct 30, 2007 | BenQ PB6100 Multimedia Projector
Bad Lamp lights even with new bulb.
confirm that it is not made in china-because some chinese lamps is not good in life time.
Dec 02, 2006 | Dell 2300MP Multimedia Projector
ASK Proxima Proxima DP2000X Multimedia Projector Logo
423 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
