Question about Ricoh Office Equipment & Supplies
Service call sc5500 How to remove error - Ricoh Office Equipment & Supplies
  • 300 Answers
To clear an sc error you need to enter the SP mode, this differs between models - if you google a search for your with how to enter sp mode you should get a result.
I'm pretty sure your error is to do with fuser temperature.
Hope this helps
Posted on May 21, 2008
My HP printer shows error code 21.1.03, what does it mean?
This error indicates problem with the service station which is on the right end of the plotter. Open the window and have a look, the most common cause I run into is a piece of torn paper preventing the head from parking properly.
Apr 11, 2015 | HP Designjet T1100ps Printer
Video Camcorder Error Message
Per SONY; To service the C:31 code, Sony recommends you do the following: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required.
Sep 15, 2007 | Sony Handycam CCD-TRV608 Camcorder
What does error code 1000-0147 mean?
Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers - KB Article - 300428
http://support.dell.com/support/top...2000-0148 = IDE error
How to Fix:
Remove and reinstall the CD/DVD Drive for the error codes:
* 1000-0147
* 2000-0147
* 1000-0148
* 2000-0148
* 2000-0149
Please see the Service manual for instructions on how to remove and replace the CD/DVD Drive. Be sure to remove and reinstall the cables for the CD/DVD Drive if you are on a Desktop Computer.
This is a Dell ONLY error code.
To find the Service manual for your model, simply search the web using:
(name and model of Dell computer) manuals
May 16, 2014 | Dell Inspiron Computers & Internet
I have a HP Z6100, and I got many times error 86:01 possible paperjam, after changing encoder strip and encoder sensor, carriage PCB. I still have 86:01 error, after Scan Axis in maintenance mode, the...
Observe when 86:10 error appearing? after intializing the carriage or immediately after powering on?
# If immediately error appearing do the below discussed activity
# after intializing if error appearing check trailing cable,service station wipers & cappings,cutter position, cutter movement & lubrication on rail.
Detatch power cable & data cable,remove right door, pull out carriage assembly from service station area (if its locked by service station manually unlock it). Remove cable connections, screws & take out service station from the printer.Place the service station out side(ensure that cables has to fix properly) connect the cables,switch on the machine, check for the error..
if error is not appearing: check the service station, found any damage replace it or shoot the problem.fix it back..
*even error is appearing: Remove carriage belt from the pully..check carriage movement, if found any hardness/obstruction? shoot the problem.
Finaly: check trailing cable( while carraige movement some tracks may lose their continuty)
Power supply.. ( check voltages)
Need your feedback for further help.. vinay229229@yahoo.co.in
Apr 11, 2012 | HP Designjet Z6100ps InkJet Printer
Error 21.2:13 on hp plotter t1100
Tech guys only:
Service station error..Remove right cover, remove & take out service station, check any objects in service station movement, remove motor clean entire unit with water you can find out lot of ink inside & too dirty clean it allow to dry apply grease for smooth movement( pl take care of pumping unit & tubes), fix it back, perform service station test ( to enter in service mode switch of the machine with power off button from front panel hold UP arrow button & OK key button then which on the from front panel button, wait till enter in service mode scroll to service station enter, three options service station,primary motor and aerosol motor select service station, enter wait till result papers on panel) best of luck...
Jul 25, 2011 | HP Designjet T1100ps Printer
How to remove error code (E000004-0010)from canon iR-6570 photocopier?
gmana ya cara benerin error e000004-0010 pada mesin canon ir6570
Jul 07, 2011 | Canon Office Equipment & Supplies
I AM GETING PROBLEM WTIH HP PLOTTER T1100, ERROR 21.2:13
Tech guys only:
Jun 11, 2011 | HP Designjet T1100ps Printer
HP Designjet T1100ps 44-in Printer Problem description: ERROR "SE 21:13, RESTART PLOTTER
Recommended for tec guys only:Error indication that service station error, open right cover check is there any obstacles in service station movement?.. check the service station connectors, if feel every thing is fine, remove service station, found dirty? remove motors, remove service station cover, clean entire unit with water, ensure that stocked ink entire should washed out, allow service station to dry, fix it up, apply grease for moving parts, fix entire back then try....for confirmation do the service test..** cleaning service station is dirty work but it will give good mileage, while cleaning take care of sucking tubes & drop detector unit.. Best of luck..
Jan 19, 2011 | HP Designjet T1100ps Printer
Hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Jul 27, 2010 | HP DesignJet Z2100 InkJet Photo Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    367 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    Adorjani Laszlo
    fares
    Level 1 Expert
    Michel
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
