Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Bissell Proheat water pump
Could I replace the water pump in a Bissell steam cleaner myself? I am female, but have some mechanical ability.
Absolutly
Posted on Jun 22, 2008
Bissell proheat turbo pump belt working still no water comes out
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Jun 18, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Bissell Proheat is not spraying water. What is causing this? and will it be expensive to fix?
It is very simple and inexpensive to fix. All you need to do is replace the pump belt. Here is the belt you need:
Bissell Proheat Pump Belt
May 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water won't spray out of the cleaner
If it won't dispense water then that means that the pump belt needs to be replaced. Here is the belt you need:
May 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissel pro heat cleaner won't expell water -- seems no suction
The reason that it won't expel water is because your pump belt is stretched and worn. You need to replace that belt, it is pretty easy. Here is the belt you need:
Bissell ProHeat Pump Belt
Jan 30, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Model 1699-1 ProHeat Clearview Plus -water and cleaner do not dispense when using trigger on handle. The turbobrush hand tool works fine.
When it doesn't dispense water an cleaner like that it means that the pump belt needs to be replaced. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
Will not dispense water how do I trouble shoot bissell proheat steam carpet cleaner
Listen to see if you can hear pump run when pressing button, if the pump does run, than either you have a clogged nozzle or screen in water fill compartment.
Jun 22, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
704 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
