Question about Frigidaire GLTF2940ES Front Load Washer
Error E10 Our washer has leaked a couple of times. I don't know for sure but I think it was the times when we had our king size bedspread in the washer. Related or not, what does the error E10 mean?
    Problem Solver:
  • 12 Answers
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on SEARCH
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
STEP 6 Also access and save, or print PDF files: OWNERS GUIDE, INSTALLATION INSTRUCTIONS, OPERATING INSTRUCTIONS, and PARTS MANUAL(These PDF files will help in replacing, repairing, and maintaining your machine.)
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for printing and viewing.
Thank you and good luck.
Posted on Jul 14, 2008
Washing machine beeps, doesn't run
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Jan 08, 2014 | Kenmore HE2 Plus Front Load Washer
Washing machine flashes error code e10 & is not filling with water
Check to make sure water supply is fully turned on. if the water supply is fully turned on, then check to make sure that your hoses are straight. if that doesnt work, tun off water supply, disconnect hose connection to the water inlet valve and check to see if the screen is dirty. you can use a small brush to clean it. if the screen isnt dirty then you may need to replace your water inlet valve. if the screen is dirty and you want to remove the valve let me know and i"ll walk you through the steps.
Feb 02, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
During any cycle washer will stop and beep and flash E10. after pushing start it will continue, sometimes will do this several times in a load.
i believe that code is water related not getting enough water maybe drain hose is too far down drain and unit is siphoning
Apr 18, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool duet dryer-error code e-1?
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
My washer is giving error code e10 and im not sure what to do my washer is a frigidaire front load
I have an error code chart that came with mine and it says a few different things for E10. 1st says water not entering washer. 2nd says water leaks. 3rd soap dispenser drawer is open. In another post there was something about a magnet needed in the drawer too. But I would suggest checking your hoses and making sure you have water and the drawer is completly closed.
Jan 18, 2009 | Frigidaire ATF6000ES Front Load Washer
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Sheets wind together in a damp ball
I have a different model Bosch dryer, but I have the same problem.
I've found that the flat sheets dry okay if you have them in with other things (like pillowcases and t-shirts). I learned long ago though that you can't put those things in with deep fitted sheets; the little stuff winds up caught in the corners in damp wrinkly wads.
So I dry the fitted sheet separately, and throw in a couple of clean tennis balls. They're noisy, but harmless, and they keep the sheet from balling up.
Oct 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Frigadaire front loader washer
Water not reaching the dispenser is one of the codes.
does it fill with water.
is it on a pedestal is the drain hose below the washer?
is it getting hot and cold water.
if water is not entering ,open the top and check the wiring to the water valves (where the hoses screw on)
Feb 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTF2940ES Front Load Washer Logo
195 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
