Question about Konica Minolta magicolor 5430 DL Laser Printer
Konica minolta 5430dl colour printer
Keeps coming up fatal error 13d0h
    Champion:
  • 214 Answers
13D0H: Parameter Chip failure
Unplug the power cord and plug it in, then turn
OFF and ON the Power Switch.
the PWB-A may be faulty.
Posted on Jun 19, 2008
Paper has jammed on roller can't open the roller any help?
Posted on Jun 01, 2010
Fatal print spooler error
what is thateans??
Posted on Feb 12, 2009
Magicolor 5430DL firmware
located at a secure Konica Minolta web site seem that Konica Minolta protects their Copier/printer firmware, available to only Konica Minolta dealerships and KMBS, need a tech
Feb 15, 2014 | Konica Minolta magicolor 5430 DL Laser...
How up upgrade engine firmware on KM 5430DL?
Have tech come out. mite be able to flash the firmware
Mar 07, 2017 | Konica Minolta magicolor 5430DL
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
How do i load a firmware upgrade on a Konica Minolta 5430DL
it requires some firmware files and another software, which you cannot get easily.so its better to call konica minolta's representative.
May 19, 2010 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta 5430DL second tray - print dialogue
This needs to be setup through the computer using the printer properties, not through the printer. You will need to be the local admin to make the changes. You may also have to go under advance and manual specify the tray and component types. The printer will not allow you to set options for trays and components that are not enabled or detected. Let me know if you need a step-by-step.
Nov 08, 2009 | Konica Minolta Magicolor 2530 DL Laser...
KONICA MINOLTA magicolor 5430DL don't recognize paper
The machine keeps track of what paper was reqested last, and asks you to change paper if the new job is different. I get the "put media" message and have to open and close the drawer if my next print job requests a different paper. So I suggest you gently open and slam the drawer a couple of times, or see if you can find the sensor switch that monitors whether the drawer is open. Also check if your paper guides in the drawer are clicked in place.
Sep 03, 2009 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta 5430DL fatal error code: 004EH
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta 5430DL error code 111112
I couldn't find the install disks so downloaded the driver from the Konica website, un-installed the software and re-installed it. After calibrating the colours everything seems fine now.
Oct 01, 2008 | Konica Minolta magicolor 5430 DL Laser...
Fatal Error 21H
FATAL ERROR CODE 21H / SERVICE CALL 21 TRANS DET SENS: Malfunction of the OHP detecting sensor
check the OHP detecting sensor (PC3A) (it's at the front above the waste toner sensor pc6)
May 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Konica Minolta magicolor 5430 DL Laser Printer Logo
946 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
